Hi okay let me start from the start. The oil pressure gauge on my R32 GTR always read around 4. I changed my valve covers and they are leaking oil and now my oil pressure reads just above 0. Is this related or just coincidence? Im shiting myself because i had to drive the car for a fair bit with the gauge reading between 0 and 4.
Thanks Adam
https://www.sau.com.au/forums/topic/335476-scary-oil-pressure/
  • Replies 44
no it will not cause a drop in oil pressure, oil pressure is measured inside the block oil galleries, any loss in oil after this point is not measured on the gauge but if u havent topped up the oil that u have lostt, if its alot, it will be the reason why ur oil pressure is so low as then the oil pump will be starving of oil
what is ur oil level on your dipstick with the car parked on even ground? i doubt uve leaked out that much though
it could just be a coincidence that ur oil pressure sender is dicking around - common problem
what year is ur car? the pre 1993 rb26 engines were prone to oil pump failure coz of the short oil pump drive on the crank collar
get another oil pressure gauge hooked up, dont bother with a compression test it will tell u nothing about ur current problem
head to supercheap, even a cheap arse oil pressure gauge will be fine, the porblem is trying to get the sender to fit somewhere, if you have a filter relocater this will be easy, if not its gonna be a pain in the butt
Use a mechanical gauge not electric as a poorly charge battery or low volts can make a bad reading. The stock oil gauge sender unit can be reached and replaced under the plenum just forward of and above the starter motor.
As someone said before when I first got my tomei oil pump I had the wrong spring pressure in it and I had too higher oil pressure but the stock gauge still read just bellow 4.
also is the oil pressure idiot light on?
if the guage is showing like a low reading ie 1.0kgcm2 and the idiot light is on i would say its all over
but if its only the guage that is showing low then it might not be true game over
i would certainly stop driving the car, check the basics, check oil level and check with a different guage
you're kind of right and kind of wrong there, fyi
the oil system is closed so it doesn't matter whether you take a reading on the pressure from the sensor in the block or from an aftermarket gauge that has it's sensor in an oil sandwhich plate between the block and oil filter, it should be exactly the same reading no matter where it's taken from
a leak will allow pressure to release from the whole system so it won't matter where you sensor is you will be able to see the change in pressure.
Oil pressure in my GTR sits lower than my GTS-T did under normal driving, still goes up the top when cold and when up the top of the rev range(5000+).
When Driving at 2900RPM on the highway mine sits just under the No.4 Mark.
Not sure if this is normal for GTR's or maybe has the same sort of principal as the N1 water pump that doesn't move alot of water at low speeds as it's meant for lower drag in high RPM application's.
Not sure if my car has a stock Oil Pump or of it's an upgraded unit that has a similar theory behind it.
I use Motul 300V Competition 15/50.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
