ive heard about people using a magical combination of nissan turbo housings and a specific cartridge to create this supernatural fabled turbo lol
i would like to know which ones ???
what size front inducer and exducer and what size rear
also any info on housing diameters and what is printed on them ie op6...mm? 45v1/2/3/4 ...mm? etc
and best combinations of said parts
but not limited to rbs any info atall would be great just wanna learn as much as possible as this really interests me
thanks guys
Mythical turbo? Supernatural fabled turbo?
I am not sure if you were drinking or smoking something last night but I bet your post made lots of sense when you typed it.
Seriously, WTF?
Turbos are air pumps.
What car, what engine, what use (daily/track/strip), what power level do you want?
Answer these questions and give the forum something to work with.
Standard nissan housings are used for convenience to allow the turbo to remain stock looking and are machined out with larger turbine and compressor wheels fitted. Hi-flowed turbos generally seem to struggle when larger than 450hp cores are fitted but there are hybrid housing from new castings or with compressor housing changes are making more power with a cost of downlow response.
There is lots of information on these topics from hypergears turbo thread somewhere just below this post through to wealth of posts over the last 7 years or so on what works and what doesn't.
lol
if you wanna learn, read through threads like the hypergear hi-flow thread here.
getting the right size turbo, you have to take many things into account:
engine size
target power
how the car is being used. ie. drift, street, drag etc
and many more
use the search function, as no doubt its been covered before
There are better threads to read than that one...unless he's after a mythical combo then perhaps he can read that thread...
Read page 39 of that tread. There is a mythical turbo there turns your RB25 into a V8. lol
Edited by kwickr33
Aaron from Sliding Performance used to rebuild turbz that worked quite well on RB25s using machined VG30 housings and Biaggio CHRAs, until it became nearly impossible to find cheap VG30 comp/turbine housings
As ppl have said, the Hypergear rebuild using machined O.E RB25T housings and their specific CHRA seems to be the go on a budget these days
hahaha i was just trying to get your attention, worked though hey, mythical....bahaha
im looking for info on the housings and cartridges inducer and exducer mesurements that is all
ive heard of people using different combinations to acheive quite a nice power figure around the 240kw mark with great response
i hear the 45v4 front and op6 rear is the largest is this true? what are the the mesurements and what cartridge has the largest steel front and rear wheels
Step 1, Initialize SAU
Step 2, Forums
Step 3, Forced induction
Step 4, Quick Ref Guide
Step 5, $350 Turbo - 250rwkw (RB25DET)
Step 6, Dont waste your time.
http://www.skylinesaustralia.com/forums/35...-9b-t22706.html
Good read, exactly the thread you are looking for. Has links to other relevant threads too I believe.
You will need access to a turbo re builder willing to do the work for cheap. Housings will need to be machined, odd parts will need to be sourced, specific instructions given to builders etc. Last time I approached GCG with the exact specs they laughed at me, primarily due to the fact they were not confident enough they could do it. They did however urge me to have them high flow the turbo for me at a cost of roughly $2000.
Now if you want to be realistic you can spend about half that having hypergear do you a high flow. I am sure he will also use whatever mickey mouse wheels you ask him to.
If your serious about it, find the turbo that suits your expectations as per the dyno thread and never look back.
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
Nah, were you pissed or stoned weren't ya.
Why you would want to make your own mongrel when the turbo shops have done the work with their own hi-flows or you can buy an off the shelf item from Garrett or Hks beats me.
240rwkw is firmly in GCG hi-flow range, HKS GT-RS in ball bearing or Hypergear can sort out one of his bushbearing turbos and you can benefit from their R&D.
Problem solved.
Not to mention hypergear have had some very impressive results of late!
As stated, go with the results that have the R&D to back.
Step 2, Forums
thanks mate ...
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
