As an introductory offer on this great new HD On Board Video System, we will do a special deal for SAU members as a group buy on the HDPro RadCam HDPro Race Pack
Full kit including standard mounts, remote control, 12 volt and AC chargers, cables, CAMS compliant Roll Bar Mount & RaceCase. Full kit price normally $780 in Express delivery, australia wide.
The price will depend on how many of you order one. For starters we will give a free upgrade to an 8GB SD Card.
Any starters??? Just leave your forum name here and PM me.
Sample Vid 1 Sample Vid 2
Edited by martyboy26
How much filming fits on a 8GB Card. 1 hour, 3 hours or all day?
2 Hours at the highest 1080P res and much longer at lower settings. You can upgrade to larger card sizes if you like.
i might be interested. could we get a suction cup too?
Yes. Thats included in the Club Racer Pack or you can buy it separately.
Moved to group buy section.
Mark, also please note the rule for group buys: http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
Full kit including standard mounts, remote control, 12 volt and AC chargers, cables, CAMS compliant Roll Bar Mount or Suction Mount (please specify which) & RaceCase. Full kit price normally $780 in Express delivery, australia wide.
Just read the Forum Rules on Group Buys, so here's the info:
Start Date: Sept 9, 2010
End Date: Sept 23, 2010
RRP normall $780
Price for all will get cheaper depending on how many sold.
2-5 $702
5+ $624
You can order the kit either with either a roll bar or suction mount.
A 4GB card (1 hour at max res) is suppliedm and you can upgrade to larger sizes if you lie.
Price includes Express delivery, Australia wide.
Payment by Visa, Master Card or Direct Deposit.
Here's a video screen dump of a rather well known car, shot from Glen Seton's BMW at the Muscle Car Masters on Sunday.
If you want more info, please go to http://www.racerecall.com/radcam_hdpro-1.html
I'm in at the 5+ price. Would also like option to upgrade to 32gb SD card, but would like to know what type of kingston card it is.
I am away for work when the GB closes so I'll pm you about payment options.
Hey Mark would you be able to do the 32GB RadCam HDPro Rally Pack as part of this? How much?
I'm also keen on this option if it's possible.
I'm after maximum record time with the option of mounting it to the body with the suction cup or mounting it to the roll cage. Cheers.
Hey Mark would you be able to do the 32GB RadCam HDPro Rally Pack as part of this? How much? I want the whole box and dice.
Sure. just the difference in cost
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
