mods:
s1 rb25
only done 20 000km since rebuild!
acl race series pistons rings bearings
npc built clutch
stainless manifold
hks 3037gt pro s turbo with braided oil lines
hks 50mm gate with screamer
respray morpheous purple
ox 607 rims 18x9.5 18x8.5 BRAND NEW
viva garage full kit
carbon vented bonet
vi-pec ecu - with custom loom
coilovers tein coilovers
front mount
shimed diff
drift catch tank
aftermarkt FMIC
flared and rolled rear guards
front(mines) and rear(whiteline) strut braces
rear cradle pineapples
slotted front roters and new bendix pads allround
:blink:
brand new windscreen
rear seats removed - but will come with car
momo steering wheel
greedy gear nob
euro style carbon mirrors with LEDs-not wired in
clarion dvd touch screen headunit with splits in front and 6x9s in rear
greedy turbo timer
2xdrift guages
3inch exhaust - no cat - and baffle removed from cannon...insane note!!
head was rebuild less than 1000km ago. valves, guides, seals, lifters!
CAR NOW HAS ROOF, PILLARS AND BOOT PAINTED BLACK! only done last week
, 2x15 inch spare rims(no tyres) standard steering wheel
. makes 288kw on 15psi :D
one bad point is that the teins may need replacing. am looking around for a new set as we speak.
looking for 18k ono with new rims and paint + 6months rego
http://www.facebook.com/album.php?aid=1603...mp;id=739171132 - pics are here :banana:
PH: 0400341730
may swap for wrx, wrx wagon, stagea plus cash my way:)
https://www.sau.com.au/forums/topic/335517-r32-gtst-rb25-hks-3037/
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
