  • Replies 79
It would be depending on the power that you were chasing.
A GT3071R will support 270>300kw (with a big rear housing) but will be laggier than a gt2871R as it has a 60mm turbine wheel rather that the 53.8mm turbine wheel found in the 2871R. Also the GT3071R runs a 56 trim compressor which will also be slightly laggier than the 52 trim which is the most common trim used on the GT2871R although the 56 trim is available with the GT2871R's.
not sure if they have any markings that determine whether or not they are "B"'s etc without measuring lobes with a dial gauge................speaking of lobes, if the cams are still in the motor, I wouldn't be touching them before checking lobes & journals regardless of mileage.
So where do I start shopping for a NS111 compressor wheel and housing? :P
The NS111 wheel is the T28 9 blade turbine wheel. I thnk that you will find it's cheaper to buy a complete CHRA than to buy just the compressor wheel, get the housing machined to fit and then get the assembly balanced. Infact it might be the cheapest to get a complete GT2871R swap the T2 turbine housing over with the T3 housing on your 2530 then sell the 2530 as a complete turbo, going this route you will probably on be paying a few hundred once the 2530's sold, and you can swap the housings yourself.
As for the cam they should have the lift and duration stamped on the back end of the cam and the shaft itself will have Tomei cast into it.
EDIT!! Looks like i could be wrong about Tomei being cast into the cam as i have just look at some pictures and it looks like they don't. I know my HKS do but Tomei mustn't.
Edited by D_Stirls
rm rb26 greddy 'ss' street-special cams are marked "grex ss"
if I recall correctly my rb25 tomei poncams were marked; were NIB so had no worries.
sounds nice on idle :)
rueben - sell the hks 2530 and purchase a new turbo, more economical that way & better value for money IMHO
reuben - sell the hks 2530 and purchase a new turbo, more economical that way & better value for money IMHO
:) By the time the 2530 sells, I'd be able to afford an R35 :(
Figured I'd just have a much better chance of building the turbo I want, rather than rely on selling, then finding the right turbo. Plus I don't have to deal with tyre-kickers.
The T3 housing i the thing that's not easy to come by. I'm pretty sure that Ryans GT2871R was actually a GT-RS, which is the same turbo except that HKS offer a T3 turbine housing where as Garrett don't. That is why i'm suggesting buying the complete turbo and swapping just the rear housings.ATP offer aftermarket T3 housings for the T28 based turbos though.
I GT3071R will be $11963 posted from the states (i think it's canada actually). That's a 0.82 A/R with the 2.75 inlet 2 inch out compressor housing (which looks closer to the factory turbo than the 4 inch inlet version.
I just had a look and ATP will do you a 2871R CHRA and compressor housing for $1204 posted.
A complete GT2871R will be round the $1600 mark posted, but then you can sell the GT2530 complete.
well i am getting mine from the US so yeah expect at least a couple of weeks
This is not an option.
Is this a typo? :)
Might look into this option.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
