hey,
I have a black r34 gtt with an impul kit, and I want to get rid of the terrible orange coloured indicators. I need some advice tho as to whether i should get smoked or clear indicators? Swinging towards clear, but I would really appreciate some opinions first. Add some photos of your cars for examples if you'd like :blink: I added a few pics of the car to hopefully make it a bit easier to decide (btw got rid of those gross yellow plates for white ones as the car is now rego'd in act)
cheers
https://www.sau.com.au/forums/topic/335526-r34-gtt-indicators/
ur car is hot as mate
go the smoked ones, i got them on my gtt (white) and they r tuff as, would be ecen better on a black car
thanks man :happy: , yea i originally thought the smoked ones would look nice coz they would match the wheels, but then i started to think clear would be good... either way, where's the best place to buy them from? (cheapest price)
i got smoked for my gtr, $105 delivered off ebay (postage was free)
ebay ones are genuine nissan / nismo anyway. if a cop complains, they have orange bulbs and be like they say nissan i thought they stock etc
Here's two black R34s with clear and smoked indicators, not a GT-T but you should get the idea :)
That first gtr is really really nice, do you know what wheels those are? (dont think they're te37's) I actually saw that one here in canberra not long ago.. or maybe it was a similar car because it had a carbon hood. Thanks for the pics mate, swingin towards the smoked look ;)
Is that $105 for both the side and front indicators, or just the side/front individually? Thanks for the advice btw
im pretty sure the car is owned by someone on the forums.
the wheels are te37's
Edited by GUN_METAL_GTR32
Oh that was just the sides, they are pretty pricey in general.. but worth it in the end :D
got my Smoked Nismo front and side indicators from Perfect Run
www.perfectrun.jp
great delivery time, excellent communication and good prices, paid around $230-250 for the front and sides delivered from Japland
PS, go the smoked!
and +1 to the rims being TE37's
TE37s they are.
I had clear indicator lenses to try, and after a couple of days, I swapped them for smoke lenses on my black R34 GT-R.
The clear lenses stood out too much. The smoke lenses blended better.
If you need more pics, PM me with your e-mail address.
Available from Perfectrun or Just Jap or Powerplayimports - perhaps even Trojan Motorsports in Mitchell (who liaise with Just Jap)
www.perfectrun.jp
PS, go the smoked!
thanks for the link and info, great site
cheers
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
