Need to get my car back on the road ASAP, thus i have the following for sale, All items are located in Pyrmont, Sydney. Smaller items can be posted at buyers Expense. Prices Listed are guides only, feel free to make Reasonablr Non Insulting/Lowballing Offer.
Contact via PM or SMS: 0419797023
Following Parts are of March 98' Automatic C35 Laurel Engine Pictured (Note Has Black Plastic CAS Making it Very late Model S2 RB25DET Same as In Skyline R34 Skyline Before RB25 Neo was introduced:
S2 RB25DET Alternator $90
S2 RB25DET A/C Compressor $90
S2 RB25DET Crossover Pipe & STD Bov $60
S2 RB25DET AFM (Pink Label) $140
S2 RB25DET Coilpacks $200
S2 RB25DET Injectors (W/ Rail & Harness) $200
S2 RB25DET Turbo W/STd Dump, Sensor & Heat Shield (No Shaft Play) $350
The Following is off My S2 RB25DET Manual Engine W/BHG:
S2 RB25DET 5sp Manual ECU $160
S2 RB25DET Manual Engine Harness Uncut (Main & Sub) *Missing Coilpack Harness & Plug $180
S2 RB25DET Bare Long Mptor W/Manifolds & BHG) $700 Or Head $550 Block $300
Other Spares:
RB20DET Alternator $60
RB20DET Head Complete (W/Manifolds) $150
RB20DET Block $100
R32 Type M Front Bar w/Lip Black $150
BMW E46 330ci Front Bar Black $150
RB20 Gearbox (Synchros Gone) $50
RB30DE 5sp Man Gearbox (W/Shifter No Crunching) $250
Accessories:
Bee-R Rev Limiter $300
Blitz DD BOV $140
GFB Hybrid BOV $180
Sheepdog BOV $100
GFB Manual Boost Controller $50
Turbosmart Manual Boost Controller $50
R34 GTR Centre Caps - $80 pair/$150 set
Defi BF Set 1- $600
Defi Control Unit II + link cables
Defi BF Blue Boost + sensor
Defi BF Blue Water Temp + sensor + adaptor
Defi Set 2 - $750
Defi BF Amber Boost + sensor
Defi BF Amber Oil Temp + Sensor
Defi BF Amber Oil Pressure + Sensor
Edited by krayzie32
https://www.sau.com.au/forums/topic/335529-s2-rb25det-spare-parts-sell-off/
hey did you receive the text i sent you around 5 o'clock? about bank transfe
hey mate
text recieved
money in acc this morning
ECU sent via express post 11am
text replied to with tracking number
keen to sell me the plastic CAS?
and a oil temp sensor for the defi?
hey mate sorry cant sell the Plastic CAS as ill be using the Head and CBF'd changing cams over...
Also PM sent Re: Defi Sensor
Cheers :)
Edited by krayzie32
S2 RB25DET Turbo W/STd Dump, Sensor & Heat Shield (No Shaft Play) SOLD
Thanks Patrick
Edited by krayzie32
Also have spare:
Defi Boost sensor $80 express posted
Defi Oil/Water Temp Sensor $80 express posted
Edited by krayzie32
S2 RB25DET Alternator $90 $80
S2 RB25DET A/C Compressor SOLD
S2 RB25DET Crossover Pipe & STD Bov $60 $50
S2 RB25DET AFM (Pink Label) $140 $120
S2 RB25DET Coilpacks SOLD
S2 RB25DET Injectors (W/ Rail & Harness) $200 $160
S2 RB25DET 5sp Manual ECU SOLD
S2 RB25DET Manual Engine Harness Uncut (Main & Sub) *Missing Coilpack Harness & Plug $180 $150
S2 RB25DET Bare Long Mptor W/Manifolds & BHG) $700 Or Head $SOLD Block $300 $250
Other Spares:
RB20DET Head Complete (W/Manifolds) SOLD
RB20DET Block $100 Alcoholic Beverages
Accessories:
Blitz DD BOV $140
GFB Hybrid BOV $180
Sheepdog BOV $100
Defi BF Set 1- $600
Defi Set 2 - $750
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
