Anyone have any info on a Shift Control Unit for S2 Stagea, I have owned this car for around 1 year and tow my race car with it.
Over the last year the A/T dash light has come on dash when i was towing on the freeway. It lost drive and just free revved. Pulled over and turned car off. Got out checked fluid was all fine, restarted car and kept going with no other problems.
After this went and got the auto serviced but they found no problems and even said the fluid was quite cleans that came out.
Was all going good for a few months but now the A/T light seems to come on the dash more regularly, all i do is pull over turn the car off restart the car and goes fine again for a few weeks.
So I looked up and done the diagnostic check that is on the forums, it’s come up with one fault which is 13. Shift Control Unit.
So has anyone had the same problem or know where the Shift Control Unit is located, I don’t have a service manual so have no idea where to start looking.
Any help would be great.
https://www.sau.com.au/forums/topic/335535-s2-stagea-shift-control-unit-fault/
Would like to say thanks for the help so far, was getting all happy thinking was on my way to fixing the problem. So pulled off the Drivers side kick panel and......... have no Shift Control Unit there????
Here is a image from my car let me know if you can see it. I will fell very dumb if you can but does not look like its there?
Any other suggestions before I start pulling covers off the car from everywhere.
dont fret yet, mine is same, apologies, diagram was from R34, but shouldnt be too far away, check under dash, should still have the part number on it to help u. There is a similar looking unit under dash between steering column and fuse panel, could be the culprit.
so, for better or worse, my drivers side panel is pretty much the same (although the relays are blue strangely enough).
I looked for the control unit part number for my vin WGNC34 102488, and it returns part not found, ie there is no part# 31036 for my vin.
maybe post or pm your vin to chook or myself, something strange here.
also, chook, i was not able to find diagram 310-A2 as shown in your screen shots....section 310 goes to 310-b1 and 310-b2 for my vin?
the part under dash is 31038-0V700, "shift control assy", not "shift control unit" ie the 31036 part, which comes up as 'no applicable part #' for yours and mine as well, but may still exist somewhere ??? but im leaning towards 31038 being the one and only C/U the more I interrrogate FAST.
worth swapping this part before you go any further to eliminate it.
Ok fantastic, at least I know what part to replace. BIG Thank you to chook and Duncan for you knowledge and research.
Will try and locate a replacement one to put in the car on Monday and keep people posted if the problem is gone may takes a few weeks or months to be 100% sure as it has come and gone a few times over the last year.
If anyone has this part lying around (I know it’s a long shot) Can I buy it please.
Will call Nissan on Monday see if they have any also.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
