Guys ,
I had a situation where i left a door ajar overnight and well you guessed it my battery was dead. My question to everyone (and i know its dumb) is actually 2 fold.
Where do you go to both jump start & charge your battery for your car.
Its either at the battery &/or at the fuse box.....
The reason i asked was that i tried to charge the battery in situ via the fuse box under the bonnet but the meter on the charger went ape and peaked at 8 amps then reset back to 0 and then again to 8 amps. Which actually scared the crap outa me as i couldnt get the connectors off fast enough...
I eventually jumped accross the battery terminas as the car was in the garage at the time so made it quite easy having the battery in the boot...
Now this question on behalf of all the dumbasses out there that were too scared to ask (me included)
Dazza
https://www.sau.com.au/forums/topic/335547-battery-charging-qu/
to jump start it you can use the terminals in the engine bay
there is the big chunky red terminal which you run the red lead to from the donor car battery/engine bay
and then run black from metal on the donor car to metal on your engine bay
thats it, with the other car off yours should crank
if it doesnt wait a few minutes and try again
if not, try with the other car running and see if it will crank over
DO NOT MIX UP THE TERMINALS - RED to RED, BLACK (METAL) to BLACK (METAL)
DO NOT MIX THEM UP OR GUESS OR HOPE FOR THE BEST
if you arent sure dont do it
if you get it wrong
it fries every component in the car along with putting your health at great risk
I guess i dumbed down the question a little much...
Firstly ...Yes i know red to red terminal , Black to black or chasis etc...
I did jump start it as the car was in the garage head first so i opened up the boot and did it that way. I am sure you can do the same from where the fuse box is as well but actually can you CHARGE from the fuse box area is really my question as I should of stated firstly...
The reason was that when i connected up the charger to the fuse box area and stated in my first post went right to the max 8amps and cutoff the back again BUT when i connect it to the battery it goes to 2-3 amps as per all my old NA cars of old...
This is the question i need an answer to guys!!!!
Darren
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
