i installed an exhaust to my car today, it drove fine all day untill about an hour ago it started missfiring. now the boost wont go past the middle of the standard gauge its not miss firing any more and its still not boosting??
what do you think it could be?
Game over.... Ceramic wheel is now down your exhaust somewhere most likely.
Better go shop for some new turbos......
I got -9's as I don't trust the ceramics, even if they ain't blown, you can do some engine damage and end up with few scored bores after the ceramic dust from the failed turbo does it's thing.
Has been covered in other Topics.
Good luck with your turbo choice :happy:
Pull the e haust off just before the cat. See if the cat has melted or if there is any parts of ur turbo sittingthere.
I did a servce on a mostly stock r33 yesterday the guy only just bought it. Was supposed to hav beennever boosted. When i dropped the exhaust at the cat there was a shattered exhaust turbine sitting therefrm a previously blown turbo. So much fo never been boosted
thats a good thing then, atleast now you know and can move onto the next stage, elimination process.
next easiest thing take it into a good tuner and put it on the dyno,
We found a unusual hiss it sounds like a vacuum leak coming from under the plenium
Is there vacuum hoses on that area? Where exactly? I tried spraying carnie cleaner all over the plenium but the noise didn't go away?
The sound is below the middle of the plenium (I think that's how u spell it)
Anyone had this prob before?
there is a lot of vacuum pipes under the plenum have a look / jack the car up or get it on a hoist, a big light and the Mrs makeup mirror and check them all out, also check your boost gauge T piece mine split and had similar problem to this, fixed up and running so much better :)
+1 Listen to this guy. My boost leak was a split hose connected to the T piece that joins up to the stock boost gauge in my 15. Something so small can really mess up the fun experience of having a turbocharged car. However my symptoms was that it would still spool but car wouldn't pull and I was nearly reading 0 on the gauge.
What other modifications have you got? Installations of aftermarkets parts including exhaust can spike the boost levels up.
What boost controller you running and is it functioning correctly? I would recommend a decent EBC like GReddy Profec II Spec B
However, failing the above, if your injectors were already close to full cycle then you're hitting full cycle when full boost hits. They reason why it's only started to do it is because the ECU being self managed has allowed the extra boost but now not enough fuel can actually be delivered assuming you have the stock ECU. Even if you have an aftermarket ECU I would recommend at least a fuel pressure regulator upgrade and a retune. The best course of action would be to get the mods you want done to it with a set of Tomei 555cc injectors or 740cc if you want to make big power on a stock engine and then take it to a reputable tuner. Stock, PowerFC or NIStune, your call.
why would it need extra fuel? its all standard ecept for exhaust. no extra boost at all. or maybe a pound or two from the new exhaust?
the car was runing fine for hours and then it just died
ist boosting normaly just less..
How big is exhaust? 3"?
It's a natural occurrence when you get more flow because of less restriction. Truth is the only reason you could be burning more fuel is because the of the increased spike from the turbo by 1 or 2 PSI as it's reading more air thus adding more fuel (need to check AFRs). This would only be a problem when you already have nearly maxed out the injectors and the ECU has permanently set the option to allow more fuel which takes some time to adjust (say an hour or 2). I'm not saying this is your problem but it's a possibility that may fall in your category. If it's stock as you have indicated just then, it's not very likely (unless for some reason you have unusually small injectors or a faulty fuel pump that conicidently decided to play up).
I would check all vac lines first as advised. If nothing just get it dyno'd and AFRs checked. AFM could even be kicking the bucket or an O2 sensor is playing up.
Definitely invest in an EBC when you get funds for it, well worth it.
Good luck.
Edited by Ruff Ryda
I had a smoke test done and we couldn't find a vacuum leak anywhere
Could the computer be in some sort of safe mode? I did put injector cleaner in there, could that have been the problem? When I took the plugs out they were a little white. Did the injector clean lean it out and trigger safe Mode?
It has a new tank of fuel in there now but the boost is still at 70% or so
If you have a boost leak the air measured by the AFM will be more than what is actually being pushed into the motor (as the leak is downstream of the AFM) and therefore you get rich mixture. Vacuum and boost are carried in the same lines at different times depending on what the motor is doing.
Did you fix the hiss? No point in doing anything else until that is sorted.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
