I would just like a simple answer will a 35.Z diff fit or not because and aftermarket one is x3 more and I need to know how much to.save for. Sick of going into my driveway and the stupid open diff spinning the wheel which has less traction which is the one in the air
Why dont YOU have a look at the mounting positions, the stub axle bolt patterns and make up your mind, or are you waiting for someone to magically say yeah I changed the Diff in my white V35 VQ25DD sedan to a 350z one and it worked?
Do you want a LSD if its going to make your car signifigantly slower? Thats what we are telling you to check!
Can't swap the stub axle over, they have different spline configurations. Can you swap the Outside flange off the stub axle! Or swap over to 3.5 litre driveshafts.
And you still don't know if your going to a longer diff, making the car slower.
Good luck.
Btw, super random first post, what are you doing here.....?
Ok I reread your post , all good much easier to just swap the flanges from the original diff to the vlsd . I don't know why there isn't more information on the net about it , it' just seems like such an easy swap to something factory and a lower price than an after market product
Ok, I read and tried to understand your post. But I'm failing.
What are you trying to Swap? from what to what?
Maybe this will explain a bit better
Here is from left to right:
03 driver side from VLSD
03 pass. side from VLSD
05 pass side from open
http://my350z.com/forum/engine-and-drivetrain/483882-what-could-cause-stub-shafts-to-pull-out-2.html
Compare the pair....
Your original
http://www.importmon...6.jpg&title=V35 R VQ25DD
Z33
http://www.importmon...791.jpg&title=Z Z33 R VQ35DE
Doesn't look like it would work, agree?
The flanges on the pictures on these diffs , the vlsd has the evenly spaced 6 holes to bolt the axle to the flange , where as the original v35 diff has 6 holes but 3 paired ...
So I was looking at the possibility of swapping the "stub axles" the part that slides into the diff to allow the shafts the mate with the diff ..
Now seeing the pictures that youbhave posted looks like the stub axle is longer obviously . So changing the full axle may be the trick
Hi
I'm also consider going to a LSD in my car but its a 300GT. Its diff ratio is a 3.13 ratio so if I go to a quaife will that mean quicker acceleration but lower top end?
Will be doing a engine swap next year but keeping the gearbox as its the same as the standard VQ35 so built to handle the power.
Cheers
A quaife will not change the ratio of your diff. It is a part that fits in the centre, not part of the gears. We were talking about a wholesale pumpkin (the whole unit) change.
That being said, might be wise if the stub axle flange fits, getting a manual 350z vlsd diff (3.5:1) as it would give you a useful boost in acceleration, as well as the LSD component.
Top end isn't really something to worry about, as long as cruising rpm is still comfortable. Really taken your car past 240kmh? Otherwise not going to effect you.
  • 9 months later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
