hi got a bit of stuff from my car that i wanna get rid of..... came out of a R32 cheers
1) Digital climate controller, no loom just the display $50
2) Standard GTS-T shocks and springs $100
3) Unknown Jap cat-back system. 2 1/2 or 3"? have to check good condition, jasma approved. . . two muffler and nice round tip with slight splice back $300
4) standard GTS-T radiator. no leaks good condition $100
5) Air con compressor and radiator, works good. $80
6) Stock air box GTS-T, afm not attached. box only $70
7) GTS-T front end panels. guards $70, Front bumper $80. four door rear bumper $100
8) centre console $50
9) panel which goes under steering column lol has the air vent. . . $50
10) R32 GTST auto trans computer $50
Please call or pm
0411 117 167
Cheers, Anth.
Edited by I8EE
https://www.sau.com.au/forums/topic/335585-r32-parts-for-sale/
Hey mate ill take the airbox if its same as 2 door! Does it include bottom pipe?
yeah it does fit, its for rb20det so will fit any rb20 motor setup with little to no modifications, call me and we'll go from there. . . bottom pipe? intake pipe?? nah just the air box dude.
this is all ive got left for now people.. ...
1) Standard GTS-T shocks and springs $100
2) Unknown Jap cat-back system. 2 1/2 or 3"? have to check good condition, jasma approved. . . two muffler and nice round tip with slight splice back $300
3) standard GTS-T radiator. no leaks good condition $100
4) Air con compressor and radiator, works good. $80
5) GTS-T front end panels. guards $70, Front bumper $80. four door rear bumper $100
6) R32 GTST auto trans computer $50
7) Moulded mud guards. $70
8) GTST Spoiler in sky blue, with brake light? $50
Please call or pm
0411 117 167
Cheers, Anth.
hey budd im interested in the front bumoer bar, can you send a picture it would be much appreciated. need to know which one this looks like before making the purchase.
cheers
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
