They are almost identical in size, if not the same front and back. But I can tell you a distinguishable difference. The R34's rarely fade but Brembos on Evo's have a horrible tendency to lose their colour very quickly for some reason. I'm guessing the clear they use were very poor.
They are pretty similar. The Evo ones are slightly larger though. Just.
And, they are a f**k load cheaper than GTR items.
You can pick up a pair of Evo 6/7/8 Fronts for as little as $250 NZD over here.
Good luck finding R34 GTR Brembos for that price.. $1K+++
Edited by gotRICE?
GTS-T Sedan (Nick) told me that EVO Brembo's have a clear coat on them and over time, the heat boils it off + the weather...
Are the EVO Brembo's interchangeable on the GTR's?
As in, are they a straight swap / fit or will modification be needed?
Hvae a search in the brake section, plenty of info
They do not bolt on. The Evo front brembo's have larger pistons and external line. Much better caliper than the GTR ones.
Not really due to weather, i would say more of brake heat. Hard driving / tracking the evo causes the caliper colour to fade. Try going for 1 track day on a set of brand new brembo calipers on an evo and inspect the calipers at the end of the day.
Therefore, when inspecting an evo, by telling the colour of the calipers, u will know how hard the car has been driven.
Nah. They all just do it regardless of track use.
The Americans complained about it when the 7's were new, it was doing it daily driving.
My mates 8 he bought with 28K on the clock, they were ok, but after 6 months they were pink. No trackdays.
Had a v35 with brembos (almost identical to 34gtr brembos) and they were POS. Mates sti brembos crapped all over it then again his car was almost 200kg lighter and then the front calipers were considerably larger.
I did a fair bit of research on these a few weeks ago.
EVO 8 & 9 fronts use a 330x32mm disc
Evo 10 fronts use a 355x32mm disc
Used set of 4 calipers approx $750-800 delivered from US ebay. A set here usually sell for a bit more approx $1000
Custom made 2 peice rotor size 340-355mm x 32mm with hats suit $330+gst each
Custom made adaptor (dogbones) $250-300 front only
Braid lines to suit $120-200 front only
Most the calipers at this cheaper price have paint problems so will need to repaint them first. More cost
GTR disc are 324x30mm thick, so not really usable.
I looked at a set of front the other day and they are pretty big. I have 19x9.5 Rays GT-c's and they would probably not fit over a 355m disc due to a couple of reasons. The wheels being 2 peice have a set of nuts around the inside that will foul the caliper. Plus they are a "B" disc rim
The Brembo pad shape is fairly square opposed to a long rectangle pad like AP or similar, so this makes the brembo caliper quite bulky.
I decided in the end, when I get around to it, I can get a 6 piston Ap design copy caliper (not chinese made) with custom rotors, hats, apdators and braided lines fully fitted to suit my wheels for $2400 drive in drive out from BHSS in Brisbane
So do your research before you try them.
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
