Hi glad i found this site...
Heres my build so far in a nutshell there will be more to come :)
Bought this about 1 year ago
a small bit of wee came out when the owner took me for a test drive
so i took it home then the fun/pain started
Step 1 service parts.
water pump
cam seals
all the bearings
trust timing belt
all the accesory belts
yadda yadda
then picked up a set of splitfire ignitioncoils from a guy in sunnybank
got a good price so happy times
then installed install the apexi super flow air filter kit
a very nice kit and well presented
goes together o.k
instructions are so so
then got some alloy subframe collars
OH YEAH!
then replaced this seal
then ordered a new stainless exhaust from jdm land
i then lost the rear turbo ;) so i ordered these bad mofo's
Garrett GT2860R-5 good for 360 hp each specs below
GT2860R-707160-5 turbo changers which are direct replacement items for the Nissan skyline R32/33/34 GTR. They are rated to 360hp each, 720hp combined, and have the following specifications:
* Ball bearing
* Oil & Water-cooled bearing system
* T25 turbine inlet flange with threaded bolt holes instead of traditional through holes
* Turbine housing has a unique "compact" 5-bolt outlet that is not interchangeable with traditional T25 5-bolt outlets
* Turbine housing is cast from high-nickel "Ni-Resist" material for extreme applications
* Turbine wheel is cast from "Inconel" material for extreme applications
* Direct replacement upgrade turbocharger for GT2556R (702987-7) used on Nissan Skyline R34 GT-R
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 360 hp
* Turbine housing option available
* Turbine housing options allow turbo to be outline-interchangeable with other turbos using the traditional 5-bolt turbine housing. Housing fits over turbine wheel but actuator/wastegate fitment may need to be adjusted.
i also bought some dumps
pic of asshole spider in my closet - now i cant go in and get a shirt so very scared
new engine and box mounts
ok so the turbo swap starts and so begins 12 hours of fun
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
https://www.sau.com.au/forums/topic/335595-my-32gtr/
  • Replies 106
Got front pipe
also got some expansion cones 2.5 to 3 inch to mate to the dumps
the outlet to the cat is 3 inches
should be good
then i can raise the booooooooooost
Cusco plate relocator thing
O2 sensor reducer nut thingo
put subframe collars in today - these make the rear end solid and makes life easier when getting sideways
ordered a full urethane diff mount bush kit from uas in Sydney
the worn rubber just above the hicas
What i thought was a fuel pump
turned out to be an afm issue but oddly enough upon opening them and buying all the soldering gear the connectors had not come loose inside which is the main problem with rb26 afm's
althogh there was a little surface rust around some of the solders on the board
so popped on to sau and the prices for used ones went from $150 for the pair up to $850
i went to molindiner and got the cheaper ones and they were as new
we plugged them in and car is well again
All back in and running again
i also made a video of how it was acting the night before last
http://s212.photobucket.com/albums/cc282/n...nt=P3150036.flv
https://www.sau.com.au/forums/topic/335595-my-32gtr/#findComment-5432527
then the day before Australia day .......
oh what a day
just got back from the shop to reattach the air con pump that was just hanging as all the bolts snapped off due to the previous co*k who fu*%ed with it
so a trip to the bolt shop
and 5 hours later i have aircon again
oh yeah it was not even a nissan pump its clearly for some other car lol
Time for a few pics i guess (the white car is mine also)
more to come !
https://www.sau.com.au/forums/topic/335595-my-32gtr/#findComment-5432531
For the other 32 owners this is the lowbeam bulb you need - ive had a busted one for months and and im sick of worring about a defect lol
While i was doing that i did the fuel filter also (those hoses are tight)
And just for lols .............. my boost controller
https://www.sau.com.au/forums/topic/335595-my-32gtr/#findComment-5432567
ok so i got my new steering rack from nissan
its also the last one avail ever as a complete unit according to the nissan people
so yeah good times ............ not great just good :D
some happy snaps of the rack change
new rack
new rack bushes
dead rack
bushes added ready to go on the car
in the car
https://www.sau.com.au/forums/topic/335595-my-32gtr/#findComment-5432572
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
