  • Replies 106
Hi glad i found this site...
Heres my build so far in a nutshell there will be more to come :)
Bought this about 1 year ago
a small bit of wee came out when the owner took me for a test drive
so i took it home then the fun/pain started
Step 1 service parts.
water pump
cam seals
all the bearings
trust timing belt
all the accesory belts
yadda yadda
then picked up a set of splitfire ignitioncoils from a guy in sunnybank
got a good price so happy times
then installed install the apexi super flow air filter kit
a very nice kit and well presented
goes together o.k
instructions are so so
then got some alloy subframe collars
OH YEAH!
then replaced this seal
then ordered a new stainless exhaust from jdm land
i then lost the rear turbo :banana: so i ordered these bad mofo's
Garrett GT2860R-5 good for 360 hp each specs below
GT2860R-707160-5 turbo changers which are direct replacement items for the Nissan skyline R32/33/34 GTR. They are rated to 360hp each, 720hp combined, and have the following specifications:
* Ball bearing
* Oil & Water-cooled bearing system
* T25 turbine inlet flange with threaded bolt holes instead of traditional through holes
* Turbine housing has a unique "compact" 5-bolt outlet that is not interchangeable with traditional T25 5-bolt outlets
* Turbine housing is cast from high-nickel "Ni-Resist" material for extreme applications
* Turbine wheel is cast from "Inconel" material for extreme applications
* Direct replacement upgrade turbocharger for GT2556R (702987-7) used on Nissan Skyline R34 GT-R
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 360 hp
* Turbine housing option available
* Turbine housing options allow turbo to be outline-interchangeable with other turbos using the traditional 5-bolt turbine housing. Housing fits over turbine wheel but actuator/wastegate fitment may need to be adjusted.
i also bought some dumps
pic of asshole spider in my closet - now i cant go in and get a shirt so very scared
new engine and box mounts
ok so the turbo swap starts and so begins 12 hours of fun
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
hey man, what are the threads and sizes of the studs as i need to buy some ?
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/6/#findComment-5572934
Call Nissan with your VIN or GCG - they will be able to supply them and will know the sizes. Make sure you get inconel ones and not just high tensile for the turbo hot side - high tensile tend to stretch from heat + gravity.
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/6/#findComment-5573021
  • 5 months later...
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
