  • Replies 106
Out of interest, have you paid any attention to your ATTESSA system? In the rain I have not really been having any trouble at all with the torque split guage going up over half pretty much all the time and right up to the top on corners and taking off from lights ect, how did yours behave before the torque splitter?
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/4/#findComment-5461633
did some things today
took old rear discs off
put new ones on
put this on
Bought some spare bits i had on order
Old air vent had fallen apart
so put a new one in
Threw the old abs bracket in the bin for more room
Edited by DAS KAMU
https://www.sau.com.au/forums/topic/335595-my-32gtr/page/4/#findComment-5465624
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
