I have a pair of Caliper Adaptors to suit someone running R32 GTR Non Brembo Calipers (296mm disk) and wants to run the 324mm disks (Brembo disks out of a 350Z). Purchased from Unique Autosports and only trialled fitted. These adaptors are modified to fit an S13, s14, s15, R32 GTST hub. They can also be used to run in a R32 GTR (non brembo)
Unique sell an adaptor to go from your standard 280mm disk to 324mm (using the cast iron caliper), but when going on a GTR Aluminium Caliper, they had to mill out a section to clear the hub.
Reason for selling, just bought new set of R888's on 16's, so don't want to spend another $2g's on rims and new rubber.
These bolt straight on and include all the hardware (caliper will need to be machined or filed slightly to fit larger bolt or you can get a smaller bolt) and if Melbourne based, I can throw in a set of 350Z 324mm disks that have been freshly machined and have 29.2mm of meat left of them.
This package cost me:
$350 for standard adaptors
$100 for machining and frieght
$180 for disks
$630
$350 and you can have the lot (pick up only or I can ship adaptors only at buyers cost)
Based in Melbourne
0409707054
Edited by sprint
SOLD SOLD SOLD
$180 for disks
$630
Based in Melbourne
0409707054
SOLD SOLD SOLD
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
