haha go me on the gtw, need to tighten my hand brake for next time for the other courses
well i actually think its got a little bit more in it, i had a fair amount of wheel spin off the line and i was short shifting aswell
Give me the keys for the GTW. Sorted :D
  • Replies 255
Posted Images
I was timing Morning Course 2 and I'm pretty sure you were 33.5 (Mell's car was 33 and you were driving it, hence the .5) I don't remember what the time was but it was up there.. I would have to have a look at the original time sheet (or a copy). From memory Reece was first in the Skyline, second in the Clio, Mitch was third in the Skyline then you were fourth, then Reece in the Clio in reverse was fifth (although it looks as though the times for the Clio in reverse were not included in the above results).. but that is just from memory, it may be slightly bais.
EDIT: I just had another look over the times and I would say that you have been put down as '34'. I remember that you started off slow and have a few tries before you got your good time. It would also mean you had the fourth fastest time which is what I said above :D
Ha ha ha, yeah I had a few goes where I spun the first two times, then nailed it pretty well two times after that...
I just wasn't sure, thought those times could have been someone elses... :D
Thanks MEL!
Thanks MEL!
Pinky Rules!!!
Apart from a single lunch-time blast in MSD00F's MX-5 (thanks again, Anna!) just before the battle courses were set up, the only burning and thrashing I did on the day was burning the sausages on the BBQ, and subsequently thrashing all your taste-buds as you all ate them. Many thanks to BenM and my little sister Rosie for help with the BBQ on the day!
Oh well, next time I'll be out there giving the wagon another hiding, and hopefully I'll have some other Stageas along as well, and NOT just sitting in the car park.
does anyone know of any upcoming skidpan days organized by any other car club or been to one? I don't care what car club it is .. I'd just love to give it another go before the car sells ;)
Driftmob are holding a drift day at EC in a week or so
http://www.driftmob.com.au/forum/viewtopic...f=23&t=3060
The setup we use is the only setup like it in Sydney.
The alternatives are drifting style or state champ style (competitive short tight course la that aren't as skyline friendly)
that's what makes it interesting!
That driftmob day looks kinda interesting, I've done the peanut track once before in my R31 and EC peanut would not be as exciting as Texi. I haven't made any enquiries cos I haven't seen any SAUers post that they're going :P
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
