hey all, not to sure if this is the place to ask but, i was just going through some classifieds are i saw this guy selling his R34 gtt. http://www.skylinesaustralia.com/forums/R3...74#entry5431174
My question is that he says that he put in ""MV Automatics stage 2 Shift kit installed"" but his car is already tiptronic, so only the valve body got put in???
https://www.sau.com.au/forums/topic/335605-shift-kits/
Have a customer with the same kit, we sent the auto across to MV and had auto built and shift kit.
Best mod for a R34 GTT auto fullstop.
nice shifts in normal mode but quick wheel spinning shifts into gear @ full noise.
  • Like 1
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5431259
Sorry, for playin dumb, but whats the kit??? when he has tiptronic already in the car....
I thought you could only get the full shift kit, is when you have an auto not tiptronic, the kit makes it into tiptronic, (or so to speak).... Cause when i ring up MV Auto's he told me that i could only get the valve body, since my car (R34 Gt-t) has tiptronic..... can someone make this clearer for me please???
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5431281
It will make the triptronic box shift a lot faster than it does normally. The rest of the operation should be very much the same.
You can't get much clearer than that :D
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5431524
tiptronic is just an electronic gimmic, all it is is a manual shifter setup and a set of steering wheel controls. Tiptronic has nothing to do with the auto performance it is just a method for changing gears.. in fact you can fit "tiptronic" to any auto gearbox that has electronic solenoids to control gear changes.
A shift kit is an internal mechanical modification which shortens gear changes and increases shift pressures so it can handle more power and stop the terrible flaring r34 auto's have std.
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5431685
^^ what he said
You can give your auto a bit of a mild shift kit if you are competent enough to remove the valvebody and know how to fit welsh plugs.
I had my gearbox guy do it to mine, remove the 1-2 and 2-3 accumulator pistons (basically sprung pistons that are there to dampen the fluid flow and give a nice soft shift) and replace with welsh plugs.
The next level up is removing balls and springs and drilling holes bigger to increase flow which is pretty much what the MV autos stage 2 kit does I believe.
The welsh plugs in the accumulators actually made a huge difference, especially on the 1-2 shift. It doesn't flare any more at all and while it is a little harsh, it's quite acceptable for my daily driver. No more piss farting around, tell it to change, it changes and just GTF in there. Cost me bugger all, about an hour or so labour and some fluid.
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5436583
I've fitted the MV kit to a 33 down here in bunbury, i took some pics of the welsh plugs before and after will try and find them. The MV kits are just a simple shift kitted valvebody exactly like bubba and status have mentioned, the hardest thing about them is not breaking the plastic electrical connections inside
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5437430
How much difference would there be (in both power handling and harshness) between just doing the welshplug into accumulator trick and the full St2 MV auto kit? Its for my wifes car so I don't know if i want too harsh a gearchange for her. I have a St2 shiftkit in my car and its probably a bit harsh for her.
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5439002
the stage 2 kit was firm but not to rough for the guy i did it for, and his missus even commented that it was nicer to drive. As for power handling/harshness it all depends on how big you drill relief holes, and which other mods you leave out. I've found with a few builders that i've worked with, each one is different in the way he sets stuff up. Now i just do it from home in the garage when i get time and space to do it for the fun of it
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5439138
I'm not sure how harsh just the welsh plugs would be in a RWD application as I think the 4WD dampens it a little bit.
TBH I wouldn't want any harsher shifts in my 4WD daily, if it was a 2WD toy car then I wouldn't care but the 2WD toy car is manual so.. :cool:
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5440423
Any chance you could go into some more detail with this process?
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5451379
Found some photos, vehicle was a 34 GT sedan.
dirty body is standard, clean is MV, the welsh plugs supplied in the kits, 2 black plugs are shift accumulators, and shift solenoids getting swapped over.
post-16364-1284702032_thumb.jpgpost-16364-1284702444_thumb.jpg[attachmen
t=304959:05052009501.jpg]
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5452040
This is the sort of kit that you can get (these photos are for an RE4R01A early 33 and patrol boxes) but are essentially the same thing, each kit comes with very detailed instructions on which holes to drill, how big to drill them, which springs you can and cant replace.
These kits can be purchased from any company that deals with transmission parts.
Computer wont let me upload the pics
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5452085
Those 2 welsh plugs are all that I had done to mine as we didn't have the info. re: what holes to drill and what else to remove.
My gearbox guy had done plenty of 33's but no 34 boxes, they are a wee bit different as there is an extra couple of solenoids.
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5452220
  • 1 month later...
I work for a car dealership and work very closely with a few performance transmission shops here on the Gold Coast. The MV kit has had very mixed reports with alot of cars having issues after installing the kit. The issue is alot of people buy the kit and think oh yay shift kit lets chuck it in with a new filter and my box is good for 500hp...
Not true, the biggest issue and killer to the 'RE' gearboxes is the accumulation factor referred to previously. The accumulation points in effect cause a buffering in the flow of fluid causing the box to have smoother shifts but by doing this it delays the engaging on the gears which therefore has the same effect as if you were riding the clutch in an manual. It cause premature wear on the clutch packs aswell as potential gear wear due to incorrect engagement.
The first and biggest thing to do to build a gearbox to be able to handle power is to removed the accumulation points (i.e. as previously described using welsch plugs) after this a slight upgrade in the valve body i.e. drilling slightly larger holes will then take up the slack in the now allowed for flow capacity of the box (MV shift kits are a waste of money and time better going to a competant transmission shop and they should be able to correctly build and modify your box to suit your cars power output and your desired effect, MV's are a generic thing and is like buying a aftermarket computer pretuned and just using it, it will offer some improvement but you are better of having a tune specific to your vehicle) After upgrading the flow if you are talking about running some decent power say for arguements sake 300 + hp ATW then it would be worthwile looking at upgrading the belts to kevlar and dual clutch packs.
Also just as a side note it is worthwile on the R33's were they run both a side radiator cooler and an auxilary oil cooler for the transmission. It is worthwile bypassing the radiator cooler and running the oil cooler alone. The amount of times I have seen the side walls of radiators fail causing coolant to go into the transmission, it is definetly worthwile doing especially since some of the radiators are over 17 yrs old. It's better to be safe than sorry. (This will not improve the shift quality, but will help protect your gearbox)
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5515720
The heat exchanger in the radiator is important as it helps bring the auto trans up to operating temperature more quickly - and the majority of trips are less than 10km. If you are worried about water getting into the auto trans (and I have never seen it myself but I'll take your word for it that it happens) then you would be better advise people to replace their ten year old radiators before they fail.
https://www.sau.com.au/forums/topic/335605-shift-kits/#findComment-5516028
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
