The heat exchanger in the radiator is important as it helps bring the auto trans up to operating temperature more quickly - and the majority of trips are less than 10km. If you are worried about water getting into the auto trans (and I have never seen it myself but I'll take your word for it that it happens) then you would be better advise people to replace their ten year old radiators before they fail.
I understand that the side core is their for that reason, but I just bypassed mine and temperatures were still well within range after allowing the car to warm up for 5minutes at idle. Though if the vehicle doesn't get warmed up correctly then yes running a cold gearbox is an issue. But aftermarket auto ones expecially in alloy are very hard to find in my experience.
As stated I have seen side cores crack before note only once on a skyline majority of ones I seen have been on Holden's and Volkswagens (I have worked for both dealerships). I bypassed mine because I am running an alloy radiator.
  • 4 years later...
Sorry, I meant it from the perspective of someone who has spend 8k+ on his auto in his R34 through various means, shift kits, standalone ECUs, coolers, etc.
Its great, when it works.
When it doesn't, manual time.
If you never go above 300rwkw, sure, I suppose it can work, but for how long?
I imagine I will break mine again in short order if my car is ever back on the road again, and when that happens, yeah, people typically don't go "Well I will down grade from 380rwkw to 240rwkw" they just go manual :P
  • 4 years later...
I just installed a stage2 MV shift kit into my re4r01a in my fd rx7 and now it changes gear at 5900rpm instead of 7200-7400.  Does anyone have any idea why?
It's useless like this, Im really annoyed. Will call them after the long weekend, but i cant see it being able to be fixed without installing a different valve body :(
I would imagine there's no compensation or feedback in the auto ECU's software for the delay between powering the solenoids, and the clutches engaging. I can't see how the ECU would know when the clutches are physically connecting. Since the shift time has decreased, the shift RPM point is now too early.
It's been a long time since I put my kit in, and I can't remember the upshift RPM changing, but I have noticed that it doesn't rev out as much as I would like.
If it's a big deal to you, you'd be better off going with an aftermarket auto controller. Swapping valve bodies won't address the issue without going backwards in the areas you need (ie shift time, flaring on changes).
There's a few things to tweak with the stock mapping anyways, such as line pressure vs engine load (rather than just TPS), lockup clutch engagement conditions, shift points vs engine load (rather than just TPS), or setting up proper timing retarding on upshifts.
I've been interested in setting up a controller myself, but nothing has annoyed me enough yet that I haven't been able to solve in other ways with my ECU.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
