I'm guessing some sort of spraypaint is in order. But considering the under-bonnet temperatures, should I be looking for any particular type? Also, what can I do about the "NISSAN" logo? It looks pretty old as well. Can you buy new logos to stick on, or should I just paint over the whole lot?
I was gonna write up a guide in maintenance but never got around to it, but i did mine a couple of weeks ago.
To be honest, I'm not sure about the high temp stuff for that. I thought about it, felt it after a good run (can touch it, so its not over 100degrees). Its plastic, therefore I don't think it holds in as much heat as the metal engine components.
Anyhow, its not a gazillian degrees in there, so just used normal can stuff ($2.50 a can) because i couldn't find the high temp in gold. One can of standard primer, and one can of the gold. I used a stack of coats (a whole can, lol) which may also aid in heat protection. For my intercooler piping i *did* use high temp as that seemed much hotter than the plastic cover.
You prolly seen mine in my sig for a while.. came up well in the end...
http://www.skylinesaustralia.com/photopost...&cat=500&page=1
still looks exactly as good as that now, with no signs of bubbling, cracking, etc. But will see how well it holds up into the future.
Not sure about the sticker.. mine was still in good condition so I just masked over it, then used a stanley knife to cut to shape (see below photo). I think if you went over it, it wouldn't look as good
If they make the high-temp stuff in your desired colour you should go with that. The difference in the paint is elasticity which gives it the ability to flex as hot components expand and contract.
This cracks ordinary paint after a while.
Are you sure your logo is stuffed? Try buffing it with some brasso to remove surface scratches and ingrained dirt.
Ta for the info guys.
No I'm not sure my logo is stuffed, but I think it had a few chunks of paint out. I'll have to take another look to be sure.
Also I have heard that some people polish the cam covers and sell them with exchange of your old ones for a reasonable price. Does anyone know anyone that does this and how much it costs? Is this something you can do yourself? I've got a drill which I think takes a polishing attachment. What exactly would I use to polish it?
Not sure if this will be an issue, but do you think the paint might help keep the heat inside where the coilpacks are?
I think it should be OK as long as you don't use the heat reflective stuff maybe ??
The last thing you want is to trap the heat in the coilpacks cause it will eventually stuff them up :(
J
Hi.
I did mine when I had the R32.
If you are going to spray anything in the engine bay, make sure you use ENGINE ENAMEL. Otherwise the paint will eventually peel off and look crap.
I polished the rocker covers when I had it.
Took a good 4 hours (all up) and a sore arm.
You MUST take them out of the car to do a decent job.
to do mine, I sanded it back to bare metal then went lighter and lighter with the sand paper down to about 1400 grade sandpaper with oil as lubricant.
then I polished it up with AUTOSOL metal polish until I could see my face in it..
A few pics can be seen at.....
http://www.pbase.com/image/22963789
http://www.pbase.com/image/22963790
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
