hey guys im just looking at buying a r33 na 96 model, not the gts4 either, just curious are there any weak points in the car i should be looking at as the importer is letting me put it on a hoist to inspect, also any body know if top secret imports blacktown is a good importer. Another question how would the stock do against some hondas e.g. integra vti-r and what are the best mods to do to the car without major changes e.g. engine .
thanks,
https://www.sau.com.au/forums/topic/335627-buying-r33-non-turbo-advice/
ive got an N/A gts4, more then happy with it for being on my p's. Dont really know what they would go like up against a hondas ect, but i couldn't really care either, For me its a nice ride that has enough power and handling to let me enjoy it.
I haven't bothered spending money on mine power wise, Bought some good tryes and got a good alarm installed + insurance ect. I dont really see it being worth it doing any engine upgrades now.
Change your oil and filters regularly and don't thrash it with out maintaining it.
I have a 96 R33 manual with the Rb25 and it's ok. It rides nicely and has just enough power but don't expect it to be fast. You will lose to most Vtech honda's such as b16a civic and integra not to mention type-R. Minor power gains can be made from a good air filter (expensive panel filter) or boxed pod, with extractors + exhaust. My advice would be to wrap some good tyres on it and keep it maintained until you are off your restricted plate and can afford something faster if that's what you want.
The Rb25 has been the slowest car i have owned but then again i'm no 'P' plater (we can drive whatever we want in NZ, even on our restricted license - which is your P plate).
One thing to look for when viewing your R33, listen for gearbox/clutch/bearing noises at idle when you engage/disengage the clutch. If you can hear audible noises such as rattling or scraping something could be on it's way out. Obviously look for any oil/water leaks from underneath and make sure the bodywork is all straight under there (no damaged chassis)
  • 3 weeks later...
thanks,
Definetly check for cracks in bushes and joints. Owned a r33 for a year and half, only realy complaint ive got about them is the stock exhaust whcih makes a really annoying raspy rattling noise at around 3000rpm.
thanks,
will get beaten by a lot of hondas, commodores, falcons, etc. some it will be close, others won't
often this is simply a bearing and isn't overly expensive to change, or really something major to put you off buying the car as often the bearing will still last for a long time. it can be a good way to get the price of the car dropped though.
lol another vs honda thing xD..........stock NA skyline is a nugget. Sorry to say ;) but if you whack on a full zorst, good intake and a light remap from perhaps a safc or something similar, it will start going sumwere lol been there and done that when my gts4 was n/a heheh. Did a 14.6 in wen it was na.
The US government never said Hussein was behind 9/11. Yes, they sure made it look like they meant that.....propaganda is nothing new in war....hell they used shit like this in WWII.
http://www.cheap-uggclassicboots.com
Edited by brightmix
thanks,
don't do it!!
well, that said, get a supra if NA.
lol @ thread, poor n/a, I'll shed some light..n/a skylines won't be much quicker than those mentioned above around the streets. But find a long straight and you notice they stop moving afta bout 120km/h lmao......
  • 2 months later...
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
