1991 SILEIGHTY
For Pics : http://www.pandablue.com/nissansilvia/foru...4917&PN=1&TPN=1
Engine Modifications
• RB20DET 5 Speed Manual
• 0.90 BAR Boost
• Pod Filter with Cold Air Partition
• HKS Super Dragger Cat-Back Exhaust (85mm)
• 3” Hi-Flow Cat
• R33 GTR Fuel Pump
• ARE Hot Chilli Type 28 Front Mount Intercooler – Tube & Fin (610 x 300 x 75 mm core) with Hot Chilli End Tanks
• 2 ½” Inlet & 2 ¼” Outlet Mild Steel Piping with Blue Silicone Hose and T-Bolt Clamps
• Intercooler Water Spray – 2 Nozzles & Rocket Switch
• Custom ARE Triple Filtered OAS
• Garage Titan Customised RB20DET BOV
Suspension & Drive Train Modifications
• URAS Urethane Drift Pineapples set to “All Round” & URAS Urethane Gearbox Mount
• UAS Master Brake Cylinder Brace
• Custom Front and Rear Strut Braces
• New (2000km) Bronzed 3 Puck Sprung clutch with 2200lbs (1000kg) Pressure Plate & High Tensile Bolts
• Machined Stepped Flywheel, New Thrust Bearing & New Pivot
• Reconditioned Clutch Master & Slave Cylinders
Interior Modifications
• HKS Type 1 Turbo Timer
• Blitz Dual SBC – Blue & Silver Version
• Relocated Battery – Boot with Maxiblade Fuse Holder & 80A Maxiblade Fuse
• CUSCO Drift Hand Brake Button – Silver
• LEVOC Racing Pedals – Silver
• Blue Neon lights in foot well
• Polished Aluminum Ball gear knob with 6 blue LED’s
Exterior Modifications
• S13 Silvia Front End Panels
• S13 3 Style Projector head lights (with fog lights) – 2 Circle, 1 Square
Wheels & Brake Modifications
• R32 GTS-t 5 Stud Brakes (front & rear – rotors & calipers)
• S14 Hubs – ABS
• R33/S14 Rims with Goodyear F1 225/50/16 rubber
Alarm & Sound System Modifications
• Viper Stage 5M Alarm – Microwave Sensors, 3 Point Immobiliser with Black Wiring
• Stock Nissan CD Player
The usual, regularly serviced:
New diff oil
New g/box oil
New engine oil - Mobil 1
Cleaned pod filter
Cleaned AFM
New & Re-gapped plugs - 0.8mm
New fuel filter
New oil filter
Timing belt changed when conversion was done (less then 10000km ago)
etc.
Done a genuine ~70000km's (engine approx 72000km's and car 73000km's).
Rego till 10/2004, Very good condition as it hasn't been abused.
All fully engineered with certificate for suspension, exhaust, engine, etc. Can provide reciepts. Majority of the work has been carried out by Greg at Autosport Engineering in Sydney.
$12,000 ono
Email: [email protected]
Mob: 0407 179 830
https://www.sau.com.au/forums/topic/33565-fs-1991-rb20det-sileighty-12000/
