I figure some one has put the two side by side at some point.
I'm looking at a R32 GTS4 currently and was considering swapping the rear guards for the GTR items . I have worked on more GTRs that the GTS4 so I'm unsure on panel dimensions and whether or not the rear guard swap will actually work or not. the one I'm looking at has a bit of rust around the rear window and in the lower rear guards.
doe anyone have a book of body dimensions for these? (or a panel repair manual for a GTR.)
I want to see if its doable or not without frigging around with other aspects of the car. the roof will have to be done as well as it has a rust spot in it.
thoughts?
https://www.sau.com.au/forums/topic/335665-32gtr-vs-32-gts4-panel-questions/
  • Replies 87
I am researching it at this point. I hava rough idea on getting the panel work done and I know what parts are involved via FAST and the costs associated with getting them. (i'm on fairly good terms with a nissan dealer for parts.)
rust line - mid rear window left side where glass meets body
bubble rust mid rear window right side similar position
rust spot - lower rear left wheel towards the back.
roof is a given as it has a factory sunroof in place. every car I had with one of these had a rust spot somewhere in it.
rest of it externally appears fine. paint is faded but you get that with any car of this age that has been outside for a bit.
As R32 GTR front cuts are brought in, ask a front cut importer for the unwanted left over "rear cut". Parts galore to complete the repair. I'm GTS 4 lover, hope to see another on the road.
I know a fellow with a yard in osaka. parts probably will not be the issue here. good tip though. have already checked with nissan and the parts list I gave them came back good with nothing unavailable. prefer new stuff as I tend to build cars , keep them and drive them for quite a while.
R32 GTS4-t btw so a poor mans GTR.
all r32 GTS4's are turbo Chris :D
you can cut the rear guard out and weld in the replacement ones, as the chassis is the same dimension-wise (R32 GTS4 coupe that is). We use the same measurements for both on the rack when pulling em straight. I'll shoot you the measurement diagram via email in the next couple of days.
Unless you're talking about an R32 GTS4 sedan, which is a slightly longer chassis.
shan , no it is a coupe. negated that bit. thought that there was a NA variant of the thing. I have never worked on a GTS4 mainly GTR's in that chassis so I do not know a lot about the variants of it.
dimensions would be good if you have them.
Yes, pretty sure they also came out with the Rb25 N/A.
That's the R32 Rb25 (not the R33) so top feed injectors and no VVT.
Nah I don't think so, not in the R32 anyway. If you're thinking of the R32 GTS25, it was RWD only.
The RB25DE + AWD combo was used in the R33 GTS4 though.
Congratulations, as a fellow R32 GTS4 coupe owner, they are a fantastic purchase. As described on this forum -"the ultimate tinkerers car". When are you getting your adjustable toque split controller? I've bought a Stagea block for a 25 det upgrade. Will be keen to follow you progress. Any one can check book a GTR.
Oooh so it's all doable, nice mate!
About farken time :D
yep had a GOOD look at rohans car today. that spot is a guard issue. so we are go. still have a few minor details to sort out before it pops up at the workshop.
doing the RB25DET thing anyway. RB20 is catcus as I understand. I have to do a bit of body work on it first (well pay someone to do it- thats not what I do for a living.) before I fiddle. TSC - once I'm happy with it and it behaves the way I want it to - THEN I will do it.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
