I figure some one has put the two side by side at some point.
I'm looking at a R32 GTS4 currently and was considering swapping the rear guards for the GTR items . I have worked on more GTRs that the GTS4 so I'm unsure on panel dimensions and whether or not the rear guard swap will actually work or not. the one I'm looking at has a bit of rust around the rear window and in the lower rear guards.
doe anyone have a book of body dimensions for these? (or a panel repair manual for a GTR.)
I want to see if its doable or not without frigging around with other aspects of the car. the roof will have to be done as well as it has a rust spot in it.
thoughts?
https://www.sau.com.au/forums/topic/335665-32gtr-vs-32-gts4-panel-questions/
  • Replies 87
I am researching it at this point. I hava rough idea on getting the panel work done and I know what parts are involved via FAST and the costs associated with getting them. (i'm on fairly good terms with a nissan dealer for parts.)
rust line - mid rear window left side where glass meets body
bubble rust mid rear window right side similar position
rust spot - lower rear left wheel towards the back.
roof is a given as it has a factory sunroof in place. every car I had with one of these had a rust spot somewhere in it.
rest of it externally appears fine. paint is faded but you get that with any car of this age that has been outside for a bit.
As R32 GTR front cuts are brought in, ask a front cut importer for the unwanted left over "rear cut". Parts galore to complete the repair. I'm GTS 4 lover, hope to see another on the road.
I know a fellow with a yard in osaka. parts probably will not be the issue here. good tip though. have already checked with nissan and the parts list I gave them came back good with nothing unavailable. prefer new stuff as I tend to build cars , keep them and drive them for quite a while.
R32 GTS4-t btw so a poor mans GTR.
all r32 GTS4's are turbo Chris :D
you can cut the rear guard out and weld in the replacement ones, as the chassis is the same dimension-wise (R32 GTS4 coupe that is). We use the same measurements for both on the rack when pulling em straight. I'll shoot you the measurement diagram via email in the next couple of days.
Unless you're talking about an R32 GTS4 sedan, which is a slightly longer chassis.
shan , no it is a coupe. negated that bit. thought that there was a NA variant of the thing. I have never worked on a GTS4 mainly GTR's in that chassis so I do not know a lot about the variants of it.
dimensions would be good if you have them.
Yes, pretty sure they also came out with the Rb25 N/A.
That's the R32 Rb25 (not the R33) so top feed injectors and no VVT.
Nah I don't think so, not in the R32 anyway. If you're thinking of the R32 GTS25, it was RWD only.
The RB25DE + AWD combo was used in the R33 GTS4 though.
Congratulations, as a fellow R32 GTS4 coupe owner, they are a fantastic purchase. As described on this forum -"the ultimate tinkerers car". When are you getting your adjustable toque split controller? I've bought a Stagea block for a 25 det upgrade. Will be keen to follow you progress. Any one can check book a GTR.
Oooh so it's all doable, nice mate!
About farken time :D
yep had a GOOD look at rohans car today. that spot is a guard issue. so we are go. still have a few minor details to sort out before it pops up at the workshop.
doing the RB25DET thing anyway. RB20 is catcus as I understand. I have to do a bit of body work on it first (well pay someone to do it- thats not what I do for a living.) before I fiddle. TSC - once I'm happy with it and it behaves the way I want it to - THEN I will do it.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
