The missus is keen to try her hand at the wheel of the mighty S13.
Now this presents a problem, I'm the standard 6ft, she's about 5'6 or so.
My seat, a Velo Podium, is currently fully fixed for me on a frame I made up using the factory mounting points and tabs from the old factory rail.
Here's the dilemma, if I add some bolt holes in the frame for her we'd still be a good inch short of where she needs to be and I had the idea of the seat mold stuff they use in the V8's when they do enduros but I'm not sure what it is, where to get it, and cost etc. The other issue is having to unbolt the seat all the time to change positions if we share the car on the same day.
The other option is to go something like a Bride superlow rail (the current frame has my helmet just clearing the roof lining) but from what I can see it puts the seat position very close to the driver side door, where as I adjusted the seating position to be central to the wheel - In an S13 you sit kind off to the right of the wheel in a factory seat.
What are others doing to get around this?
pretty tough problem with no easy solution unfortunately. like you say sliders will fix it but they are not always ideal in mounting location or height. seat insert is a good idea talk to places like revolition or race and rally, or GMP etc. most would be custom made by teams themselves I'd say. but it's probably the best idea.
Interesting. Brett From Revolution tells me the V8 teams are just using the exanding foam stuff from a spray can available at any hardware store and a rubbish bag.
Seems a bit industrial lol
Just get some custom steel side mounts made that offset the seat forwards and then partner that with a steel base frame with two pre-drilled sets of holes so you just un do 4 nuts/bolts and move the whole thing forward. You may end up having to have two sets of locations on the side mounts as well
I lol'd. In China they are also doing leg extensions if you prefer the missus to go through the painful stuff.
I have just been through this with rails as the solution on a custom front chassis mount - have not had a chance to mount the seat yet and see if I hit my head.
Bride Superlows have adjustment left-to-right in them. As to whether it is enough I don't know, but I never felt as though I was sitting askew once I adjusted mine.
I'm tall, Kel's short. Bride low rails for me, just bolt in, easy/hassle free.
originally had multiple bolt holes but you just can't change it quickly, let alone during a pit stop
That's good enough for me then. I'm not 100% clear on the types though. I notice there's superlow TYPE MO and YS etc.
Does it matter?
Yes it does. You need the measurements of seats that they take, and different ones will allow for different heights. Is it a bottom or side mount you're after?
I've got a velo with the Velo side mounts bolted to it. They bolt to the side of the seat but have a 90 deg bend and mount flat to the frame I made up.
These
http://velo.websitestation-client.com/site...t%20bracket.jpg
Hmm. Too many variables measurements wise blargh.
I don't think it matters which way I go, some modification is going to be necessary, either to the bolt hole locations of my velo mounts on the bottom where it connects to the rails or the bride mount side holes where it lines up with my seat.
To me this looks easier
http://www.frsport.com/Bride-Type-MO-Super...S14_p_1225.html
All I'd have to do would be drill some new holes in the bottom of my velo mounts where it connects to the rails.
I see what you mean though with something more like this design
http://www.japshop.co.uk/acatalog/EVO_8_Seats-Rails.html
No issues with the lower hump part of the seat clearing the cross bar.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
