yeah, just wondering what people use in their radiator, some some water is fine some say not some use additives like water wetter.
I just flushed it with a hose and filled it with water and a bottle of corrosion inhibitor
Do radiator flush additives work?
Is coolant really necessary?
What do you reccomend?
What works?
https://www.sau.com.au/forums/topic/335673-what-do-you-put-in-your-radiator/
Yes I would use coolant or your water pump won't be too fantastic down the track and that water will turn brown :D
Water is for topping up or adding to coolant concentrate mixes. I'd only use it if I had no choice.
Rust and scale removers work alright when flushing.
Yeah i read something about coolant lubricating the pump, I usually use it but didnt realize i'd run out.
But i also read another guy says hes used nothing but water and redline water wetter for 10 years with no problems..
So just wondering what i should get to add to it
Edited by Arthur T3
definatly flush the system and use coolant, i use nulon long life coolant pre mixed $20 for 5 litres so you need 2... or u could by the concentrate and mix it yourself with demineralised water. tap water for flushing only....
in my old corolla pre 80s i use the corrosion inhibitor and water wasnt really designed to run coolant...
Yea one of the reasons you are suppost to use coolent is because it has a higher boiling point than water. The water will evaporate through the overflow bottle after long drives. I use rust repellant coolant, however if you have a corroded cooling system just buy the radiator flush and do it yourself shouldn't take long.
I only use straight water to flush the system. Once it's flushed I just pour in pre-mixed Nulon red along with 500ml of Motul Mo'Cool. Works fine for me and has kept the temps consistently lower during the hotter months.
Yeah i ran a bottle of flush through it for over half an hour, not sure if it made a difference, the water that came out was brown but so was the the flush mix i put in it.. :P
Another guy told me he just runs the engine with the hose stuck in the radiator.
I also read somewhere that plain water actually cools better.
But i do remember the old man topping up the radiator in the his HJ monaro all the time, He had to check it daily. I have never had to with coolant so i guess there is truth to what you say mr massive..I didnt know this b4..
orange juice
never use tap water ever this is the worse thing u could do... oh l lie u could do worse: bleach, drain cleaner, fuel, fluorine gas, OJ.
the only water you should use is distilled water most good auto shops stock it in +10L bottles or just use the pre mix
flush with the tap - put the screw back in - fill it up with tap water + some radiator flush - turn engine on with radiator cap off - idle for a few mins - drain / flush with tap water - fill up with coolant + top up with distilled water.. has never failed me. (someone correct me if im wrong)
^^ yeah thats what i did..
Someone told me to fill the radiator with coca cola and then throw a packet of mentos in it. Apparently the reaction is really good for cleaning out the corrosion..
Has anyone tried this??
That someone has been watching "Mythbusters" too much. Diet Coke + Mentos = BANG.
That someone ought to be shot!
Wanna shotgun??? MORE BANG!!!
back in the day some mechanics i know used to use coca cola to flush radiators and even clean the oil stains off the floors. however doing that with the coke sold today and all you will end up with is a sticky mess. as with most things these days, they aren't as potent as they used to be.
....I also read somewhere that plain water actually cools better.....
absolutely right, water is about the best thing in the universe for taking energy and getting hot slowly. only 2 problems - stopping rust (corrosion inhibitor) and it freezes at 0.....
When I was having cooling problems I ran straight distilled water + redline water wetter, it ran literally 10-15o cooler than coolant.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
