Hey Guys and Girls
Im looking at buying a D/SLR camera but i dont know heaps about them.
I will manly use it for motosports and car related things maybe try some photography.
Just wondering what camera you guys would recomend.
i would be happy to spend the money to get the right sort of camera.
Sorry for a annoying question but any help would be awesome thanks.
https://www.sau.com.au/forums/topic/335689-dslr-cameras/
How much you willing to spend? The new 1DIV costs $6K :D
In all honesty, i suggest getting a crop camera (APS-C) because of the extra reach (1.6x the focal length is actual focal length).
Couple of questions?
Have you ever used a DSLR?
Can you hold a 3kg dumbell in your hand all day long? that will depend on if you can carry heavy lenses e.g. 70-200 2.8 IS and camera body.
Do you know anything about DSLR settings or camera settings?
No point spending $1600+ on a camera body if you don't know what 3/4 of the functions do :D
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5431940
I have a 1000D and its an awesome starter for $1k. Lasted me a year before I started upgrading lenses. Similar cameras are the 450D and 550D, although the 1000D is about $800 nowdays.
Or the 5DmkII is an awesome bit of gear! You can buy that then I'll swap you my entire kit for it :P No built in flash, but who uses flash anyway??
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5431952
5DII isn't really suitable for n00bs who want to do motorsport photography though. Great for automotive, but not for motorsports. Slow focus, slow FPS, terrible AF point distribution also (very bunched up and gets super annoying!).
I highly recommend a Canon 7D for motorsports but i think its "too much camera" for someone just beginning. Hell, i'm still getting my head around the numerous options it has and playing with the AF modes.
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5431988
So your saying I should say "buy the 7D then I'll swap it with my 1000D cos it's more suited to you"? Cos I'm happy with that :)
I need to put in my signature "My photography advice is all well and good, but ultimately listen to Kory!" :P
Hahaha well that would help you out lol.
Yes, yes you do :D
OP - As Zennon suggested, get the starter/entry level kits, play around with them, then when you feel limited, upgrade your glass/body. Its not good to jump in the deep end with photography, so much to learn!
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432169
Are you the kind of guy who changes every single setting to see what it does?
Are you likely to spend hours and hours and hours trying random stuff to get ExACTLY what you're trying to achieve?
If yes then goto 'BUY HIGHER END CAMERA'
Are you generally kind of lazy?
Will you be happy with a nicer, sharper image than your point and shoot camera?
Are you pretty busy with work and other junk?
If yes then goto 'Buy more basic unit'
If you get something in the middle it should give you enough functions to do what you want/need, with a bit of room to grow and learn and expand.
A Nikon D90(what i use) or a Canon 550D would be good options if the 2nd set of questions sounds more like you, if you decide to get some more professional kit talk to Kory (FST513) he knows that end of the market better than most of us in here :P
good luck with what ever you decide
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432368
Thanks for the help guys ive been looking at the Canon d500/d550 so i reckon ill probally go with one of these.
my budget was around $1500
and yeah im the kind off person to play with all the settings.
Thanks agian
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432711
W000 another Canon user! Go Canon!!!! :D
You'll be thoroughly impressed with the 550D shooting stills as well as video. Be sure to stock up on high speed SD cards. The 550D is basically a 7D just trimmed down.
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432887
7D is nice and fast. Not really very hard for beginners imo. If you're willing to READ alot and experiment even more. Reason i know this is 7d was my first only recently. Well worth the coin. As for lens, May be worth getting something with a little more zoom if you're shooting track days.
All that aside there are some pretty good photographers on here so I'm sure you'll have plenty of support regardless of what you decide :D.
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432934
All that aside there are some pretty good photographers on here so I'm sure you'll have plenty of support regardless of what you decide :).
'Tis true, depends on how fast you pick it up, though there is much less to learn on a entry level camera like a 550D compared to a 7D. The AF on a 7D is very complicated compared to basic 9 point AF on the 550D. Then you have all the custom functions and settings, really depends what your going to use the camera for and if you will stick with it and experiment, like you said. Photography gear doesn't depreciate that much, so easy enough to buy a 550D and then if need be, sell it off and pick up a 7D etc..
I see your point - But there is no point paying that much coin for a camera if he/she is unfamiliar with DSLR's as well as not using 3/4 of the functions the 7D can utilize. For the extra $800-$900 spent on a 7D over a 550D, thats already almost a 70-200 f/4 non IS.
If budget is only $1500, 7D is out anyway.
Good to see you like the 7D and it's suited to your photography though :D
Edited by FST513
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432946
Good point.. missed that bit tbh
If you want longer reach maybe on of these options..
500D & 18-135mm: $1,215
500D & 18-200mm IS: $1,495
550D & 18-135mm IS: $1,369
550D & 18-200mm IS: $1,679
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5432947
you really only need the 550D if your planning on shooting video... I picked up a 1000D (entry level DSLR) to take on holiday in Europe as I just wanted to shoot still stuff and didn't want to be paranoid about losing breaking an expensive bit of gear... just got the upgrade twin lens kit with it
anyway its a great camera, more than enough if your just starting out
for examples check out my book I put together here http://www.blurb.com/books/1557242
there's a bit of photoshop there but most of the pics are how they came off the camera
https://www.sau.com.au/forums/topic/335689-dslr-cameras/#findComment-5433115
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
