Looking for some feedback as per the topic description.
We have an S13 where the factory "rubber and four bolt with plastic spacers" coupling is quite worn, creating a fair bit of slop. I've since investigated my 32 and it too has some play there, though not dramatic.
Does anyone have thoughts on replacing this item with either;
A. A new factory item.
o,r B. An aftermarket billet piece.
My initial perception is that that factory is best, as I have a hunch that having this coupling solid will transfer rack rattle into the rack itself, wearing the rack prematurely as opposed to the coupling absorbing it.
Does the perceived "benefit" to more direct steering feel outweigh the concern I have?
Thanks in advance gents :P
https://www.sau.com.au/forums/topic/335724-steering-coupling-rack-to-column/
I wouldn't be replacing a rubber coupling with solid, as this won't allow any misalignment at all. The rattles / NVH transmission wouldn't be a major drama though.
I don't know if there are harder rubber units available, or whether you can replace it with a different type of coupling (spider / uni etc). The RX2 had a spider coupling which I rebuilt with poly cushions. It tightened up the coupling, but unfortunately the rest of the RX2 steering system was made of camembert, so the thing still had terrible steering feel (despite rebuilding / replacing everything that could be unbolted).
I had one in my s13, it was a real FUN job to get out.
It did sharpen the steering up and didn't present any major vibration/feedback. However i didn't replace if fo this reason, it was more to do with a clearance issue with the slack of the column on the starter motor.
Notec used to make a replacement urethane type, but since the merger with whiteline/red ranger I can't locate them.
I've put a billit one in mine, but havn't got to use it yet... mainly cause it came in the box of bits in the car. But all the people I spoke to who have used them said it improves the wheel feel. The old one usually ends up flying accross the work shop when you go to remove it
I would suggest that the factory unit is there to reduce MVH in the steering wheel and reduce noise transfer to the cabin from the front suspension. I cannot see how it would impact on the operation of the rack or cause undue wear in the steering to replace it with something more substantial.
In our R32 we have replaced it with a billet alloy unit which seems to make the steering feel more direct. In my R33 build I am tossing up between another billet unit and one of the urethane replacement ones - either way it will not be another factory item.
I have a solid in my s13 with no power steering.
Any rack rattle, brake shudder, ripple strip hits all gets transferred straight into my hands :)
It's not a mod i'd do in anything street driven.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
