As title says, I have the GTR badges for sale. Front and rear, will not seperate. They are 100% authentic. The front badge has the black backing on it so that it stands out from the grille, whereas fakes dont have the backing. and the rear badge is larger in size. They are metal and not plastic.
Purchased both for $200. Willing to sell em both for $100.
Preferably Melbourne buyers.
Thanx.
p.s. I think everyone knows what a gtr rear badge looks like cos there always going faster then most people... so ive attached the front badge so that u can see what i was talking about with the backing.
  • 3 weeks later...
Assuming that they're both brand new, I'll take the front one for $50 or both for $100 depending on how you feel about the above offer from butthead.
You'll have to post them to Sydney though... I'll pay postage.
Where did you buy them from? I'm after a front badge too after someone kindly removed mine for me (bless 'em) but nobody seems to have any fronts available.
Try JustJap or UniqueAutoSports... One of them (if not both) will have the front GTR badge in stock if you're in a hurry...
