2000 wrx want to drift again. so looking for a skyline
gold coast queensland.
manual turbo
125,000kms
boost controller
boost gauge
dual port bov
has had the full service with the timing belts all replaced
both rocker cover gaskets replaced
gearbox in seal replaced
drives extremely well hits boost nicely. have receipts for proof.
pretty standard
no rego or rwc just ran out
needs sti wing brake light wired up, stock bov, spotlight bulb
parker lights not working, front right headlight has moisture inside, and
the rear window tint needs to come off.
11,500 but trades for skyline. or possibly a quick 180sx
Edited by ransom99
https://www.sau.com.au/forums/topic/335764-trade-my-wrx/
ok have done some work on it, heres whats been done
tail shaft to gearbox seal replaced
rear left diff seal replaced
top plate on gearbox replaced
spotlight bulbs have been replaced
the rear tint has been taken off because it was messy and according rwc ppl a hazard
no more moisture in the head light
new brake pads fitted this morning
all it needs now is the wing brake light hooked up.
https://www.sau.com.au/forums/topic/335764-trade-my-wrx/#findComment-5434315
2000 WRX GC8 Sedan
new price $13,500
this is a brilliant wrx, very reliable, comfortable, low km, cruiser. had alot of attention the last few months bringing it back to life and im happy with how it is.
engine:
EJ20 4 cylinder Unleaded Turbo 2.0L (1994cc)
125,000kms still original engine.
boost controller running stock boost
dual port adjustable blow off valve
has had the 100kms timing kit replaced in the major 100km service
2 weeks ago underwent both rocker cover gaskets replaced
standard turbo setup spools really well no issues.
complete and up to date service.
gearbox: just a standard gc8 5 speed manual gearbox
just had the top plate gasket changed
the rear main seal replaced
selector seal has also been replaced.
replaced the lhs axle seal
standard exhaust
standard suspension
very clean interior all standard
exterior has few tiny small 10 cent dings on passenger door
sti wing
brand new genuin subaru right hand side headlight due to old one having moisture inside
new bulbs for spotlights
fixed the wireing problem and bulbs for the parker lights
fixed the tail lights
6 MONTHS REGO has been placed on the car.
had it for sale for cheap but now my gc8 is completely up to scratch.
https://www.sau.com.au/forums/topic/335764-trade-my-wrx/#findComment-5438250
hey mate, im interested, but has to be very negotiable on that price, i live in sydney. send me a PM with ur name and number if ur willing to negotiate on prices etc and ill fly up and have a look.
https://www.sau.com.au/forums/topic/335764-trade-my-wrx/#findComment-5449101
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
