A mate took his R33 to Dyson Rotary to have a power run done on the Dyno, everything is stock except the exhaust and an EBC(11psi), as you can imagine the power curve was up and down all over the place, for the next run they disconnected a sensor and did another run and suddenly the power curve was alot better and a good 10kw above the previous one everywhere! When he asked what that sensor was all he said was "it's a trade secret". The sensor he unplugged was the one above and to the right of the temp sensor, that goes into the head. Does anyone know what this sensor does and is it safe to drive around with it unplugged?
No idea what the sensor is but it'd be intersting to see if it'll start and drive when cold, also whether the car pings like a bitch when the temperature gets high. On the dyno you atleast have the confidence that they are monitoring for ping.
I just had a quick look under the hood.
On the radiator hose mount there are two plugs (sensors), is it one of these? Or is it the plug that is righ next to the radiator hose housing that connects to a big (3 inches long) hexaginal nut thing that bolts into the head ?
J
sounds like the wire from the variable valve timing
Now that makes sense. I have a mate who has done an s14 sr conversion into an s13 running s13 computer.
He installed a switch to control the vvt and it makes a massive difference. When he was tuning the car on the dyno there was an easy 20kw difference in the midrange but it tapered off at the top end. There was a definate difference at the top end when it was on/off though i cant remember the figure.
JAY95R33 that's it, the 3 inch long hex shape thing that goes into the head. I'm not sure if it controls the VVT as I thought that was the one on the end of the camshaft but maybe it's all related as BHDave said by switching it on and off it made a difference on the dyno, ask your mate whether he attached the switch to this or not? It's definately not the knock sensor because I believe that is on the block not the head.
I have a friend who unplugged his VCT while on the dyno, I think the results were less lower end torque and higher top end. I can't find the scan of the printout, but they're quite a different power/torque curves.... As the VCT turns off at 5500rpm not sure why it would make more top end power thou. Perhaps revs more freely not sure. I've unplugged mine before and it was smoother the lower torque at low revs was fairly noticable.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
