A mate took his R33 to Dyson Rotary to have a power run done on the Dyno, everything is stock except the exhaust and an EBC(11psi), as you can imagine the power curve was up and down all over the place, for the next run they disconnected a sensor and did another run and suddenly the power curve was alot better and a good 10kw above the previous one everywhere! When he asked what that sensor was all he said was "it's a trade secret". The sensor he unplugged was the one above and to the right of the temp sensor, that goes into the head. Does anyone know what this sensor does and is it safe to drive around with it unplugged?
No idea what the sensor is but it'd be intersting to see if it'll start and drive when cold, also whether the car pings like a bitch when the temperature gets high. On the dyno you atleast have the confidence that they are monitoring for ping.
I just had a quick look under the hood.
On the radiator hose mount there are two plugs (sensors), is it one of these? Or is it the plug that is righ next to the radiator hose housing that connects to a big (3 inches long) hexaginal nut thing that bolts into the head ?
J
sounds like the wire from the variable valve timing
Now that makes sense. I have a mate who has done an s14 sr conversion into an s13 running s13 computer.
He installed a switch to control the vvt and it makes a massive difference. When he was tuning the car on the dyno there was an easy 20kw difference in the midrange but it tapered off at the top end. There was a definate difference at the top end when it was on/off though i cant remember the figure.
JAY95R33 that's it, the 3 inch long hex shape thing that goes into the head. I'm not sure if it controls the VVT as I thought that was the one on the end of the camshaft but maybe it's all related as BHDave said by switching it on and off it made a difference on the dyno, ask your mate whether he attached the switch to this or not? It's definately not the knock sensor because I believe that is on the block not the head.
I have a friend who unplugged his VCT while on the dyno, I think the results were less lower end torque and higher top end. I can't find the scan of the printout, but they're quite a different power/torque curves.... As the VCT turns off at 5500rpm not sure why it would make more top end power thou. Perhaps revs more freely not sure. I've unplugged mine before and it was smoother the lower torque at low revs was fairly noticable.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
