Bought the ceffy bout 8 months ago for a decent price just something to drive to work and back in. Then my partner bought a new mazda 3 and I aquired her lancer.. So we took the car back to Hervey Bay (thats where im from) and it sat in the shed and ran out of rego. Though to myself in this time I could put a car together and still be able to get to work and back. So the old rb25 came out of the ceffy and the 26/30 built started. Picked up a rebuilt rb30 off a mate here in brissy and then it all started. Sourced a rb26 head had it reco'd, light port and a set of tomei 270deg 10.25mm lift cams and tomei buckets/springs fitted also went for a single throttle setup for something different. Looking for a streeter to make 450-500rwhp all day every day.
So the things Ive collected on the way are:
Jun plennum
90mm throttle body
hks fuel rail
sard 800cc injectors
sard fpr
dash fittings
2 x 975 external pumps
haltech e11v2 patch loom and 3bar map sensor
crap load of dash fittings and braided line etc
Pulled the rb30 bottem end apart and found that it had been reco'd maybe 100km ago and is in very good condition.
ACL pistons
ACL bearings
Ballanced Rods/crank
Need to fit new water pump and a possible nitto oil pump/crank collar. Also looking for the turbo side of things at the moment maybe a 6boost manifold and a gt3540 or maybe T04z something along those lines as the power output is at the lower end of the scales and I want it to be a street car with decent response.
Got stuck into the engine bay with a mate thanks Keiron aka (Gtir-keiron) got it prepped and paintedd blue with green zerelick. Put it back together the next day.
so it started out like this:
Uploaded with ImageShack.us
base down
clear on and a close up of the colour change
parts all fitted back up
Small collection of parts
https://www.sau.com.au/forums/topic/335807-ants-rb2630-a31-ceffy/
  • Replies 75
Decided to go gt42r as we came accross a deal at a good price. So we sourced a trust manifold and a tial 44mm wastgate off a guy here on the forum. So hopefully we will get the wiring loom run and the computer in the car aslo still have to tap the block for the second tentioner and fit the head to the block, fingers crossed it'll be done this weekend ;).
thanks man should be interesting pretty much got eveything now so just gotta bolt it together and tune it fingers crossed itll be finshed very soon. It a bit hard when you live in brissy and the car is 3hours away :P
No worries man I'll get picks up asap, missed out on going home this weekend got called into work. Next weekend should see the wiring loom, engine in and turbo on and lines finished off! Not long now.
yeah will be cept ive been ripped off on my manifold and gate as ive bought one from a forum member and have been done $900 as its been over 2 weeks since ive paid for it and still havent recieved he also screwed over someone else on here too..
To be honest ant and i had the engine bay stripped down and painted in about 5 to 6 hours.
Motor already out of the car helped alot.Ant is really good with strip down work as he has pulled so many cars apart and put them back together again.
Wow anthony you got ripped off by a forum member dude? Name and shame time really mate and im sorry to hear about that.
I hope he comes clean and sends you the items mate really.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
