Splitfire Coilpacks / Jun Oil Pump/ Takata Harness / Nismo Gear Knobs
Been back to Japan recently and sorted out a bunch of parts I have had in storage in Japan and now they are up for sale.
Direct Ignition Splitfire Coilpacks
SF-DIS-001 for BNR32, BCNR33, R31, HCR32
SF-DIS-005 for BNR34, ECR33
These are brand new in their box and never used.
$580 Delivered
JUN High Capacity Oil Pump for RB26 (Brand new)
$1280 Delivered
TAKATA 4 POINT RACING HARNESS MPH SERIES
Brand new in the box genuine Takata racing harness .
Model MPH 341
Expiry date is 2014
$580 Delivered
NISMO GENUINE GEAR KNOBS
NISMO S-Tune Shift Knob 5-MT Leather
NISMO S-Tune Shift Knob GT500 6-MT Urethane 12mm thread $92 delivered
NISMO S-Tune Shift Knob GT500 6-MT Urethane 10mm thread $92 delivered
NISMO S-Tune Shift Knob GT500 6-MT Titanium 12mm thread $180 delivered
pm me if the NISMO S-Tune Shift Knob 5-MT Leather
is under $50..
Cheers. and if they fit 34 gtt:D
Sorry bloke ..too cheap at $50
Ok pics..
SPLITFIRE COIL PACKS
TAKATA HARNESS
NISMO SHIFT KNOBS
LEATHER SHIFT KNOB $70 DELIVERED
ALSO HAVE A BLACK NISMO DURACON SHIFT KNOB $65 Delivered
ALSO HAVE THESE JDM NUMBER PLATES FOR SALE $60 plus delivery
All parts are genuine article or money back guarantee !!
60 for the nismo leather gear knob delivered.
Sorry mate ..price is stated
best price for JUN oil pump delivered to 3064 melbourne.
pm me
Sorry mate was away for a wedding..
Jun oil pump SOLD !!
SPLITFIRE COILPACKS NOW $550 DELIVERED
TAKATA RACING HARNESS NOW $550 DELIVERED
ALSO STILL FOR SALE
NISMO SHIFT KNOB PRICES ( AS IS )
APEXI POWER INTAKE (GTR33/34) (Price As Is )
SARD FUEL REGULATOR $170 Delivered
  • 4 weeks later...
hi, could i grab a nismo leather gear knob for the 70$ deliveried please.. thats the cheapest ive seen them new.. it will fit r33 skyline hey?.. thanx. hit me up with details..
pm replied
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
