  • Replies 210
Because everyone is bloody amazed. and interested :)
Nothing really to be amazed at....there are heaps better tradesmen around then me!Ive seen some a mate of mine make a panel with his hands,a hammer and a bag of sand....its absolutely amazing to watch a guy like that...very rare these days.....now thats skill!
Ok so now that the vehicles front has been removed you can see the two main upper structure bars have been left intact.These two run all the way down to the upper hinge pillar and acts as the hinge support,as you can see in the 1st pic....In the second pic you can see the sill panel has been marked for the join on the outer skin....In the 3rd pic the front is lined up to mark the outer skin join of the A pillar....In the 4th pic the front is coupled in to the Upper strusture bars/hinge pillar supports and A pillar.Lock in A thanks eddie!;)The 5th pics shows the new fronts hinge pillar holes lining up with the dowl pin/threaded part for the door hinge...looks like my mesurements were up to scratch!
in the 6th pic the bulkhead skin has taken quite a likeing to the original floor pan so in the 7th pic its screwed together to hold it in position while we check that the door gaps are true....in the 8th pic the doors are fitted and gaps are squared up ok....the next step is to weld it all back together and refit the sill strustual bars/sill panels....more on monday
Cheers
I thought someone would have something to say seeing as tho minesdatsun copped a caining...wheres my caining?
Thing is the majority of cut and shut are done to minimal cost (and care) and just to get the car "looking" like its fixed so they can stick panels back on. Then they flog it off to the first buyer they can find and somebody gets ripped off. And maybe one day in the post-mortem they examine the car and find out the reason it caved in on itself after the accident was because a cheap and shitty job was done.
Seeing as you're actually going to be driving it and have to deal with the safety consequences I'd imagine you'd be spending some time on doing a proper job :)
Hi Troy, are you going to "stiffen" it up while everything is accessible? A few well placed TIG zippers in the front end makes a heap of difference. I'd also do the A pillars, door openings, inner guards, suspension towers and particularly the firewall. We see over 200% increase in torsional stiffness by doing this and that's before we add the roll cage.
I reckon it's a few extra hours well spent.
Awesome :) Looks like is coming along well. One question though. How do you get your measurments right, surely if the two were not attatched correcty doors would not shut well etc.
Its not really that difficult,Jig companies like car-O-liner ect supply underbody measurements on almost every model vehicle available.These measurements are from certain points on the underbody so before the job starts a quick measure is taken from these points and if it doesnt measure up,we pull the car about until it does or until the doors fit on right.Then we disect the vehicle as shown.Its all at factory seams so when its pulled apart at the same part on both vehicles,you cant really mess the job up.As far as the sills and A pillars go when one is cut apart the off cut is then placed on the other half as shown i one of the pics (you can see a factory produced elongated hole on the sill where the scuff panel goes, these are a great indicating tool for marking out)
Ok...now we have the new front on and welded...the next step is to change the 2WD chassis rails to 4WD ones....the first step is to drill the spot welds off to remove the existing chassis rails...the 1st pic shows the rail removed....the second pic shows the 4WD rail siting on a trolley jack being lined up...we then clamp it on with vice grips and get underneath the vehicle with a tremel gauge and check our underbody mesurements,this is done using the main rear diff cradle mount as a base "0" mesuring point....we then have a series 7 or so underbody mesurements that run from this "0" point toward the front ,each of them are at certain holes on your chassis rail (obviously running toward the front of the vehicle)Next time your under your car,have a look on the rails and see all these holes for yourself.I should have taken a pic of the tremel gauge,i can do it and add it in later.This is a Slide rule with a tape measure built into it as you slide the tape runs up...quite a handy little jigger.After we check the underbody measurements we can move the front rail foward or backward to get it within spec.If the old sealer left on the skirts lines up perfectly to the new rail and the measurements check out square this indicates a well thought out job prior to comencing.It turns out that i must have had my thinking cap on...it fitted perfect :).The next pic shows the rail welded on and home...the next is of the right rail completed....the last pic shows the rail spot welds as seen from the inside of the vehicle...
So now the rails are fitted next we will clean up the joins and place the seam sealer and insulation mats on the floor....should i keep going on posting the process or are people bored yet?
Cheers
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
