  • Replies 210
first of all Doughboy...i havent eaten since i started work on the car...first thing was to get food into me :P...nah actually it was a servo so i took a couple of pics.....mesh,i cant really say i was please with the service of ANY anodising place,the jobs they do may be great but the service was terrible(i didnt even get one part completed from them)so i done it myself in the end.......the exhaust sounds great however a tad noisey but this can be adjusted with driving habits....i have past a few of the boys in blue,but you just have to judge the gear and throttle position and its not the vile......the air intake sensor on these vehicles are at the right hand side of the intercooler tank....between the turbos and the intake manifold...that pic i took was after the vehicle had been running for well over an hour,i was quite amazed...thats why i took that pic...but last night was quite chilly
troy, will we see another R34GTR at the track soon? Glad to hear you are on the road, it must feel great.
I have a temp probe just after my Hybrid monster cooler and it usually maintains temps within 1/2 a degree of ambient at over 60kmh. Under 60 it tends to warm up a bit more but a full boost run through secnd to third will see the temps plummet. must be nice though to have it built in :P
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
