  • Replies 210
first of all Doughboy...i havent eaten since i started work on the car...first thing was to get food into me :P...nah actually it was a servo so i took a couple of pics.....mesh,i cant really say i was please with the service of ANY anodising place,the jobs they do may be great but the service was terrible(i didnt even get one part completed from them)so i done it myself in the end.......the exhaust sounds great however a tad noisey but this can be adjusted with driving habits....i have past a few of the boys in blue,but you just have to judge the gear and throttle position and its not the vile......the air intake sensor on these vehicles are at the right hand side of the intercooler tank....between the turbos and the intake manifold...that pic i took was after the vehicle had been running for well over an hour,i was quite amazed...thats why i took that pic...but last night was quite chilly
troy, will we see another R34GTR at the track soon? Glad to hear you are on the road, it must feel great.
I have a temp probe just after my Hybrid monster cooler and it usually maintains temps within 1/2 a degree of ambient at over 60kmh. Under 60 it tends to warm up a bit more but a full boost run through secnd to third will see the temps plummet. must be nice though to have it built in :P
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
