  • Replies 210
Because everyone is bloody amazed. and interested :)
Nothing really to be amazed at....there are heaps better tradesmen around then me!Ive seen some a mate of mine make a panel with his hands,a hammer and a bag of sand....its absolutely amazing to watch a guy like that...very rare these days.....now thats skill!
Ok so now that the vehicles front has been removed you can see the two main upper structure bars have been left intact.These two run all the way down to the upper hinge pillar and acts as the hinge support,as you can see in the 1st pic....In the second pic you can see the sill panel has been marked for the join on the outer skin....In the 3rd pic the front is lined up to mark the outer skin join of the A pillar....In the 4th pic the front is coupled in to the Upper strusture bars/hinge pillar supports and A pillar.Lock in A thanks eddie!;)The 5th pics shows the new fronts hinge pillar holes lining up with the dowl pin/threaded part for the door hinge...looks like my mesurements were up to scratch!
in the 6th pic the bulkhead skin has taken quite a likeing to the original floor pan so in the 7th pic its screwed together to hold it in position while we check that the door gaps are true....in the 8th pic the doors are fitted and gaps are squared up ok....the next step is to weld it all back together and refit the sill strustual bars/sill panels....more on monday
Cheers
I thought someone would have something to say seeing as tho minesdatsun copped a caining...wheres my caining?
Thing is the majority of cut and shut are done to minimal cost (and care) and just to get the car "looking" like its fixed so they can stick panels back on. Then they flog it off to the first buyer they can find and somebody gets ripped off. And maybe one day in the post-mortem they examine the car and find out the reason it caved in on itself after the accident was because a cheap and shitty job was done.
Seeing as you're actually going to be driving it and have to deal with the safety consequences I'd imagine you'd be spending some time on doing a proper job :)
Hi Troy, are you going to "stiffen" it up while everything is accessible? A few well placed TIG zippers in the front end makes a heap of difference. I'd also do the A pillars, door openings, inner guards, suspension towers and particularly the firewall. We see over 200% increase in torsional stiffness by doing this and that's before we add the roll cage.
I reckon it's a few extra hours well spent.
Awesome :) Looks like is coming along well. One question though. How do you get your measurments right, surely if the two were not attatched correcty doors would not shut well etc.
Its not really that difficult,Jig companies like car-O-liner ect supply underbody measurements on almost every model vehicle available.These measurements are from certain points on the underbody so before the job starts a quick measure is taken from these points and if it doesnt measure up,we pull the car about until it does or until the doors fit on right.Then we disect the vehicle as shown.Its all at factory seams so when its pulled apart at the same part on both vehicles,you cant really mess the job up.As far as the sills and A pillars go when one is cut apart the off cut is then placed on the other half as shown i one of the pics (you can see a factory produced elongated hole on the sill where the scuff panel goes, these are a great indicating tool for marking out)
Ok...now we have the new front on and welded...the next step is to change the 2WD chassis rails to 4WD ones....the first step is to drill the spot welds off to remove the existing chassis rails...the 1st pic shows the rail removed....the second pic shows the 4WD rail siting on a trolley jack being lined up...we then clamp it on with vice grips and get underneath the vehicle with a tremel gauge and check our underbody mesurements,this is done using the main rear diff cradle mount as a base "0" mesuring point....we then have a series 7 or so underbody mesurements that run from this "0" point toward the front ,each of them are at certain holes on your chassis rail (obviously running toward the front of the vehicle)Next time your under your car,have a look on the rails and see all these holes for yourself.I should have taken a pic of the tremel gauge,i can do it and add it in later.This is a Slide rule with a tape measure built into it as you slide the tape runs up...quite a handy little jigger.After we check the underbody measurements we can move the front rail foward or backward to get it within spec.If the old sealer left on the skirts lines up perfectly to the new rail and the measurements check out square this indicates a well thought out job prior to comencing.It turns out that i must have had my thinking cap on...it fitted perfect :).The next pic shows the rail welded on and home...the next is of the right rail completed....the last pic shows the rail spot welds as seen from the inside of the vehicle...
So now the rails are fitted next we will clean up the joins and place the seam sealer and insulation mats on the floor....should i keep going on posting the process or are people bored yet?
Cheers
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 馃檹馃従
    • Sport. I didn鈥檛 rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
