Hi All,
I have an R34 GTT manual sedan with specs as follows;
Stock turbo and internals
Splitfire coilpacks
Iridium spark plugs
Exedy HD clutch and lightened flywheel
Walbro 550lhp in-tank fuel pump
Blitz turn-flow cooler
Cooling pro alloy radiator
BC racing coilovers
R32 76.5deg thermostat
Exhaust from the turbo back with hi-flow cat
Profec B Spec II
Basically I wanted to do all the supporting mods so that in a weeks time when i get the PFC + handcontroller installed and tuned it should all be fairly safe and it's about as far as my budget could stretch before going the next step of a new turbo and bigger injectors etc.
Basically I was wondering if anybody else had similar mods running a stock turbo and how they've found it, what sort of boost you're running and any advice on the best high and low boost settings. I was thinking low of 7 and high of 12 but I've spoken to a few people who think low 10 and high 14 would be acceptable. Any help would be greatly appreciated in the way of real-world experience, kw/hp numbers achieved and any pros and cons. I realise the 34 turbo is ceramic and can shatter at high speeds so I want to be relatively cautious until I can afford a new turbo down the track.
cheers,
Steve
Go with your instinct.
12psi high boost is "relatively" safe and you will get about 200rwkw +/-10kw
This has been covered to death. It is possible it might last 2 years it might last 1 day but commonsense should tell you that the lowest level of boost you can get away with and get still get reasonable performance is the best place to set the peak boost.
A good tuner should know what is reasonable.
Cheers Wolverine appreciate the assistance dude.
The tuner is really good and has a good reputation so maybe it would be best to address these queries with him direct, he's just a very busy man and don't wanna bug him too much with being a noob.
On the basis that it could last 1 day or 2 years I think you're right in saying to go with my instinct - 2 years would be cool coz I'm sure I'd have cash for a new turbo by then but if it lasts any shorter than that I could be carless for a while.
i have ran 11.5psi for yrs in my r34 sedan not tuned at all i have is a full exhaust and pod /cai, spark plugs regapped slightly.. never had a issue but i dont drive it hard often. you however have all the supporting mods id say low 10 or so... and high 13 would be acceptable on the stock turbo....
Edited by rgr34
Just tell the tuner 12psi max, thats it.
It's your car, its your call regardless.
For long turbo life, 12psi is the limit realistically.
Cheers mate, 12psi max seemed to be the going consensus from all the info I've read so I think I will just ask to make that the max and in all your wisdom I wouldn't second guess it now you've said it also.
thanks Nismoid.
Mine was tuned at 11psi and made 215rwkw. Very similar mods too.
Cheers mate that's awesome, I've not been able to find any comparison as most people at this stage have upgraded the turbo.
This is going to be a huge noob question and I expect flaming (please be gentle). From everything I've read the R34GTT is 206kw out of the factory (not sure how true this is as all data points to the r32 gtr being the same so I was thinking this may of been a lie due to power restrictions in Japan =/ )
I'm gathering the 206kw is measured at the flywheel or something because I'd be shattered if all my mods and money and time added 9kw =/
If i were to go on the basis that my car stock is 206kw at the flywheel and I may be hoping to expect 215kw at the rear wheels is there any easy way of determining (even very roughly) how much of a power increase I've gone to from stock. (ie does anybody know the stock rwkw for an r34gtt)
End of the day I don't want to be hektik and get a tune just for numbers on a sheet, i want real world response and really love and enjoy my car i'm just questioning this for curiosities sake and with the hope of learning/understanding a little more.
When my r33 Gts25t S2 was stock it made 157RWKw.
Factory power ratings are always at the flywheel, never at the wheels. R33 GTS-T was 187kw at the fly, and I believe roughly 154kw at the rear wheels. If the R34 GT-T was actually 206kw at the fly, then I would assume somewhere in the vicinity of 170-177kw at the rear wheels.
Also, I'm not sure on the 206kw deal between the R32 GT-R and R34 GT-T, but it may be concerning the "gentleman's agreement" between the Japs, in which they didn't advertise their cars as having more than that
My 34 GT-T with catback exhaust and pod filter made ~165rwkw. So I would expect a full stocker to make ~150rwkw.
Have a look here for the modification guide:
http://www.skylinesaustralia.com/forums/Ni...p;mode=threaded
Most stock GTS-t and GT-t skylines have shown around 60kw in drivetrain losses.
So a stock GTS-t often comes in around 130rwkw and a GT-t around 145rwkw. Some higher some lower so take it with a grain of salt as a dyno is a tuning tool not an absolute truth meter.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
