Shutter Problem
Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
Temu raptor, lol. At least the owner isn't your typical ranger danger lot -
They definately are coming back around, so many GTRs coming through again with them.
Besides which. If you have a Haltech waiting - don't waste your time and effort and money trying to get the boost sensor. Just f**k the stock ECU off and put the Haltech in. Then you won't need the boost sensor.
