I previously posted in the Vic forums but got no where so i thought i would (should of originally) post it in here.
Guys ,
I had a situation where i left a door ajar overnight and well you guessed it my battery was dead. My question to everyone (and i know its dumb) is actually 2 fold.
Where do you go to both jump start & charge your battery for your car.
Its either at the battery &/or at the fuse box.....
The reason i asked was that i tried to charge the battery in situ via the fuse box under the bonnet but the meter on the charger went ape and peaked at 8 amps then reset back to 0 and then again to 8 amps. Which actually scared the crap outa me as i couldnt get the connectors off fast enough... BUT when i connect it to the battery it goes to 2-3 amps as per all my old NA cars of old...
I did jump start it as the car was in the garage head first so i opened up the boot and did it that way. I am sure you can do the same from where the fuse box is as well but actually can you CHARGE from the fuse box area is really my question as I should of stated firstly...
Now this question on behalf of all the dumbasses out there that were too scared to ask (me included)
Dazza
https://www.sau.com.au/forums/topic/335956-battery-charging-question/
yes you can charge from there. when jump starting and charging you should put the negative to part of the engine to give the starter a better chance and because it usually well connected to the battery. sounds like the terminals of the charger were shorting out or trying to run something else whilst charging. i cant imagine what else. try it again and check before switching it on connections are good and cant short out
charge at the battery. jump start at the battery too. in the past i've tried jump starting at the fuse box and it would barely turn over. moved around to jump start at the battery and started fine.
also when charging you should have the battery disconnected from the car, otherwise you can risk blowing stuff if there is a surge.
Cheers guys.
yes i know to use the engine or component for the -ve and disconnect the battery while chargeing I just thought it odd that the charger peaked at 8 amps at the fuse box yet straight after (2 mins) when connected to the battery it draws 2-3 amps.
I suspect this is due to the battery location in the boot . I mean the battery would have to have cables going thru to the motor hence it may put a load when charging from the fuse box?
who knows.....
Darren
Thats strange. I always jump from the fuse box and it turns over without effort.
    • For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work. Like everything, there is upholsterers, and then there is upholsterers. Some really great upholsterers for automotive restos won't even appear to have an online presence.   My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
