  • Replies 119
  • 1 year later...
Been playing with the GTR a bit...latest mods are an E85 conversion.
950cc injectors, HKS GT600 fuel pumps upgrade...and a tune from Willal.
Im also using the Sucrogen E85 (same stuff the V8 supercars use).
Result was 400kw atws..the thing is damn quick....leaves black lines from each tyre under acceleration in second gear.
Off to WSID on Wednesday to see where its at....then off to the Temora 1000 next weekend followed by a track day at Wakefield on the 27th.
Thanks to Martin at Willal for tunes
HKS pumps and 950cc injectors
Sucrogen E85
result...blue line is the 98 tune...needs a little work ...will get onto that later
stumbled across this pic from Wakefield
awesome mate
keen to know why my car made more power on the same dyno and same fuel
what else do you have on the car? be interesting to know if you dont have an intake for eg, working out how much power it's worth working backwards from our dyno plots
in for your 1/4 times. I got rained out last sat and couldnt run
Edited by domino_z
Different dynos, different days, different fuels, and you had bigger inlet pipes etc domino. That explains most of the difference! :)
Other than that the tunes are fairly similar
How similar is fairly similar. I bought an email tune off you a while ago which is great. I have the cobb AP (Opviously) DW950cc injectors, HKS pumps, your (Willall) midpipe, the same down pipes as domino_z and ADM 2011 turbo inlet pipes (bigger ID).
Will one of your email tunes for E85 with confidence give me the same results as these guys with no issues?
Does your email tune cater for my specific mods? as I dont really want to have to take the car to SA if I can help it.
I will be running the sucrose E85 from the drum, will that make the tune different than that of domino_z which was your E70 tune?
Is there much of an advantage in getting the car dyno tuned by you rather than email tuned by you?
Do you need cobb data to do the email tune more accuaretely?
Sorry Martin for all the questions but I am really interested.
the way i understand it, given the willall maps have been based off running as low grade as e70, putting in sucro wouldn't really make that much of a difference - a bit like choosing bw different brand 98 rons
i may be wrong though, and if there's considerable gains to be had from the sucro juice, ill be coming past your place G35 for a top up before hitting the quarter :thumbsup:
So, went to Eastern Creek dragway last night...mixed result.
ran 10.96 @ 127mph
Had two runs....
First run the launch didnt feel clean so I got off it and braked at 3/4 track (to keep above 11.00)....ran 12.1 @ 69mph
Second run launch felt good so I stayed on it....
Looking at the data in my Vbox I should have stayed on it the first run..it was running strong at 7.0 @ 103mph half trrack and my 0-100klm/h was 3.0 sec ...second run was 3.2 sec
Looking at the video below you can see that the car actually bogged when shifting into second. Its hard to tell but 1st gear was all wheel spin (I had an aggressive 4000rpm launch map) I shifted at the rev limit but because of the wheel spin the vehicle speed was not there and she bogged...(the tacho goes as low as 3000rpm after the shift).
The bogging down probably cost me 2-3mph and a few tenths.
Looking at a heap of timeslips on the US GTR forums you can see low a 1.6 sec 60 foot is the norm....I think I would have nailed a 1.6 with a few more runs but there was no chance they would let me back on the track..
Enough excuses...
timeslip
In car video of the run
Edited by Speedah
so what happens now, did they write down your numberplate so you cant go back
If you run under 12.00 (which I have done in the past) you need an ANDRA licence..the 10 sec pass is logged against you ANDRA licence number...
Someone else could take the car and probably get away with running
Speedah, do something about those brake temps before you destroy them.
This guy seems to be onto something - http://www.nagtroc.org/forums/index.php?/topic/61425-willall-gtr-brake-cooling-system-track-results-updated/
As the only effective brake cooling system that exists in the world for GTR its worth your consideration.
Forum sponsors CRD and Mercury both sell and install WR35WS :)
  • 1 month later...
  • 7 months later...
New wheels and springs installed today
Advan GT
20 x 10 front
20 x 12 rear
with 285 and 335 Michelins
Also fitted 1in lowered swift springs...these springs actually lowered the car 3/4in at the front and 1/2in at the rear.
Pics dont do it justice...looks very fat on the road.
Thanks to Michael at Acute Performance in the USA for a perfect transaction on the wheels/tyres and springs
I have also just done the 2012 front end conversion
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
