  • Replies 119
  • 2 months later...
Hi ho Hi ho....its off to Willal I go...
Jumped in my car yesterday after having driven it 1/2 an hour earlier with no hint of what was to come.
Started it, shift to reverse, dash lights up like a Christmas tree with faults and throttle input does nothing...car wont move.
AWD system fault light is on (see top right below) along with check engine light.
Plugged in my Access Port and found code P0847
Had a look at the GTR service manual...code is the following...
Shit....doesn't sound good
Called Martin at Willall....common problem, factory pressure sensors shit themselves. There are 3 in the transmission and are not accessible.
Needs trans/diff removal and transmission disassembly to repair. I have my suspicions that the sensor is actually OK and the pressure is in fact low from a blown seal.
What pisses me off is that this failure has nothing to do with any mods to the car...it happens to bone stock R35s. If my car was stock I could take it to Nissan and they would replace the complete transmission under warranty.
So, car is being shipped to Willal on Friday...while the trans is out will do some bullet proofing mods.
All going well Im hoping to travel from Adelaide to Melbourne Saturday 2nd Feb, stay the night and have some runs at Heathcote drags on the Sunday (there are a few R35s going for runs). Heathcote allows sub 11 sec passes with no cage...will be good to have a play with different levels of the launch control and better my single pass 10.62 at WSID
This is the first and only fault I have had with the car in 2.5 years and I have absolutely flogged the arse out of this thing....cant complain
Pretty standard failure. Talking to a few of the boys who do some work here on the West coast, they all seem to do it between 25,000-40,000kms. Sounds like you got to the very limit of age / kms before they let go.
'South Side Performance' now do complete plug-and-play sensors for the R35 as it's such a common problem.
They're only $200. Your biggest expense will be labour:
http://www.sspperformance.com/product/gr6-transmission-pressure-sensors-/
hope you can make it to Heathcote Kev
seeing what you can run with mod'd turbos vs my full bolt on stock turbo same day same track will be a great comparison for everyone (including myself) who is on the fence whether to take that next step
great opportunity to upgrade the trans - im still on the fence whether to do this as preventative or wait till something goes wrong
Speedah did you try the Warranty path with Nissan???
Also another thing, what did the 2011 front end conversion set you back??? I'm considering doing this myself with my 2010
Yes, I talked to someone at Macarther Nissan who was very helpful...told him the full story. He explained the proceedure they have to go through to gain approval (from Japan I assume). Short story is the car would be there for a week or two while they diagnose/wait for a decision then I would be charged $600/$700 to then to say they can't help me.
Im not too worried...I would rather put parts in it that dont fail. I was very fortunate that it happned inside my workshop. A week ago I was driving in the Sydney City centre during peak hour...I dont know WTF I would have done if it decided to pack it in there.
Edited by Speedah
Ill be there...try and round up as many R35s as you can.
Stock wheels back on for Willal trip no. 2
Ready to go. (car has now been delivered to Willal)
If you need to transport your car from Wollongong/Sydney area interstate by someone that actually cares Mick is the man. Some of you may be familiar with his 7.4sec Torana MV454
I seriously hate transport companies all together. While I didn't have issues with CEVA, I had a fuel contamination issue a few weeks back and the GTR had to be tray back transported to Moorooka Nissan for draining. I made sure I taped up the front lip (2 layers) just in case it was scratched. Sure enough, the tape was fully scuffed when I picked it up from Nissan the next day. Luckily there was no damage.
The transport used was the GTR Roadside Assist preferred - Wilson Transport - in Brisbane. I do not recommend them, nor will ever use them again!
Edited by Wardski
Have they fixed this pressure sensor problem in the later model R35's?
Nup. Transmissions are almost identical in that regard all the way to 2013. With all GT-R's its not a matter of if it will happen, its more like, when it will happen :P
Edited by Wardski
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
