I have by chance downloaded an 808 page complete R32 GTR Workshop manual.
Now as I don't have a GTR yet it will only be used in the month's to come.
This PDF file zipped is 21Mb, and came from
http://www.lancer-evo.net/manuals/misc/r32.zip
I used my works Internet to pull it in about 10 minutes, it would have been over an hour at Modem speeds.
After my last post with the R33 Parts diagrams, there is no way I can get this to everybody so some one may want to host it :worship:
I can send small sections as needed, but most ISP's will stop that size doc.
Hope we can all use this.
Regards
Mark
https://www.sau.com.au/forums/topic/33596-complete-r32-gtr-workshop-manual/
  • Replies 44
This link came from the Skylinesdownunder forum and is 136Mb in size.
It is a RAR file of the fast disk, Nissan manual, part numbers etc.(use wrar330.exe to uncompress)
I have downloaded it and installed it on my XP machine, but it does not work fully.
This could be due to the 1999 date on it and that it needs Windows 98.
http://forums.skylinesdownunder.co.nz/show...ght=nissan+fast
There is a URL http://194.149.66.28/auto/gr.rar
Run this thread then select the URL, right click save target and wait.
The uncompressed version is 336Mb. I have started to debug why it fails by getting the VB416dll files. Hope someone cracks it, meanwhile I will carry on by putting it on Win98.
Hey guys at least its free, I don't beleive in making fellow Skyliners pay for good knowledge.
Good luck.
Mark
Got them both - thx muchly for the links.
Over 56k (yawn).
A bloke oin EBAY got caught with this - he paid over $300 for a supposedly genuine hardcopy of the GTR manual, that was obviously just a print of this PDF.
Now, all I need is my car and I can start to fiddle!
Hi Cobra-Mark
I to have down loaded it on to XP machine and sound to have the same VB problem. did you install it as the read me file said to do for windows.
I was going to try loading the other 3 zip files and installing them with the .exe as it said to do if you are using dos. the 4 or 5 files are together in one DIR.
All I am getting at the moment is a window opening with 3 or 4 options and exit. exit is the only thing that works.
Keep us posted on what u try and if it works
Cheers
Sherlock_NZL,
I have given that a go, but it requires the vbdll416 library, as th einstall does not even run without a small error at the end.
Still on course to prove it this weekend.
Will let you know.
Mark
Cobra_Mark
I have got the Training manual  that teaches you and shows you how to work the parts part of Fast using XP, that's as far as I have got at this stage.
Cheers
Can you send me the training manual to [email protected]
Hi Skyline33
Yes I can do that
You must have a working copy of Fast I guess, If you want to know how to use it.
mine doesnt work if I could have a copy please.
What size email can you take
What year are your files. mine are mostly 1999
What operating system are you using
Cheers
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
