  • Replies 189
I should be in or at minimum pop round for a look see. I have it in my calander and will cash on the day if there are spots left or if anyone pops something later on in the day.
In the wife's Terror-tory again??? :D
lool bring afew spare afm's just incase :D :D
nah that engine is out, the blu 1 has a n/a in it now, but i have a rb26 s13 that i might bring but just wondering if it would be all good bringing a track car because last time everyone was in stock streeters
As long as it isn't too loud anything can enter :D
yea i was talking to your dad and he was saying you were going to put a na when the rego ran out, lol bring it along :D would be awesome to see how the 26 runs without a heavy skyline to lug around :D
isnt too loud ? i thought u skyline boys like the sexy loud noise of a 26 goin off ? if the 26 isnt ready i have a ca 180 i can bring. Anyone know where we can send forms so i can lock in my spot ?
It isn't us that mind the noise, it's the people in the housing near by :)
It isn't us that mind the noise, it's the people in the housing near by :ermm:
ah, pansies need to harden up. ill find out what car im bringing next week, prob be a ca 180 so wont b too noisy. Any news on where to send the forms ?
[email protected]
im in doof ill give u the forms monday
[email protected]
UPDATE : I AM COMING TO DO EPIC EPIC SKIDS IN THE AUTO lol
just thought i would though that in there lol
[email protected]
also has the fax number been amended yet?
Yes
believe it when i see it :P
Oi you, enter, send forms to [email protected]
Noise - the maximum vehicle noise emitted does not exceed 95dB(A) measured at
a point 30 metres from the track edge by approved measuring equipment.
From texi form last sept..
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
