um yeah was just wondering if I can rock up this time without paying for the (AASA?) licence because I paid for it the last time but haven't actually received anything?? Was told it'd arrive in the mail (not sure how when you don't even have my address) so yeah...lookin forward to this
  • Replies 189
the asaa licence is a 12 month licence so you wont need to pay for it again.. you will have to contact either one of the execs or cams themselves to get a copy of the licence as they may not have had a addess to send it like u said. BTW your address should of been on the entry form
I entered as a N/A before the conversion..
see here:
you will have super throttle response and might end up being quicker than most of the turbo ppl
see how slow i am now!
p.s. START SENDING EMAILS OR FAX'S PPL!
You didn't mention to someone that you didn't give an address?
Best bet is to call AASA direct and tell them your address so they can send it. It's probably sitting on a desk somewhere ready to go
Just to confirm, AASA and CAMS are two different organisations. Either way, we accept both a CAMS licence or an AASA licence, and as AggroDave said, they're both usually valid for 12 months each.
wasn't going to do this one, not sure if my new car will be up to it but then I saw the courses. Can someone send me a PM about helping out? If you help out you can do a few runs at lunch right? That would be enough for me right now I think.
Yeah actually my address was on the competition entry form ... but I haven't received anything in the mail yet. Any chance someone can chase this up for me ? R34 with DR34PR rego plates on entry form.
The competition entry form, and the aaas form go to 2 different places. We just send away the aasa licence forms. You will have to contact aasa yourself unfortunately and chase them up.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
