  • Replies 189
So apparently I might be at this...
Later on in the afternoon, if we replace the last cone with a blow-up "1 metre soft-vinyl punching bag effigy" of our President "Steve-O", would you like to...
a) drive around him
b) nudge him or
c) *** him
:blink:
Edit* the blow-up bag is rated useable by "3 years+"
wow this looks really fun, where can i find all the relevant details about what you need? cams aasa, i have niether :D scruitineering? sound levels, i have a 3.5inch turbo back exhaust that too loud? helmet don't have one of those, place i can borrow/hire?
wow this looks really fun, where can i find all the relevant details about what you need? cams aasa, i have niether :down: scruitineering? sound levels, i have a 3.5inch turbo back exhaust that too loud? helmet don't have one of those, place i can borrow/hire?
Basically, check the first post. CAMS is available on the day; $50 for L2NS (texi events, etc) or $100 for L2S (speed events like EC, etc). I got L2S and scored like $140 off my comprehensive insurance, so I was $40 ahead, winner! You'll need a fire extinguisher as well, Autobarn have them for $30 or so. I've used the bolt that holds the passenger side of the rear seat down as my bracket mount.
Scrutineering is basically to make sure everything's ok, fire extinguisher is there, nothing loose around the cabin, no oil leaks etc. If your 3.5" turbo back isn't too loud, it should be fine. Basically, as long as it's not one of those ones that people 400m down the street go "here comes that asshole again", you should be right.
Helmets... You can actually get them quite cheap, I got mine for $100 inc post with two spare visors.
http://cgi.ebay.com.au/FULL-FACE-MOTORCYCL...=item35ad82ffb2
Check this guy's stuff out, and make sure to measure your head if you're gonna get something from there. The dark tinted visor he also sells (not mirror) is quite good, too.
But by far the BIGGEST thing you will need is a desire to destroy tyres and do fast times :D
wow this looks really fun, where can i find all the relevant details about what you need? cams aasa, i have niether :P scruitineering? sound levels, i have a 3.5inch turbo back exhaust that too loud? helmet don't have one of those, place i can borrow/hire?
MCAS do cheap helmets that you can pick up instore. The bloke there thought i was mental wanting an open face helmet for drag racing until i mentioned i was doing it in a car :)
ima going, just lazy gettin my shit together
*edit*
with hte entry form, do you have to put both drivers down as the entrant or just pick 1?
Woo. Got my entry form, will be faxing it this arvo and paying the dosh. Will be my first time out. I watched the last one so cant wait to get the blue whale out there to see what shes got. Will need the AASA licence and will have to scab up some spare tyres. Cant wait. See you all there.
*EDIT Payed and Forms Faxed. See you out there!
Edited by Calsonic14U
can you add my name to the list. I will be there 100%, i just want to my SAU membership first.
Also those Helmets above are fantastic. I ordered one off them about 3 weeks ago and it came 2 days later. He's highly recommended
Guest
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
