Dont know if anyone can help me or point me int the right direction but I'm chasing a shipping crate for an engine block that I'm sending to Japan..
Yes,yes have tried google and have got a few replies from emails but the companies I have spoke to want to sell them in bulk.
I'm after one engine shipping crate to send an engine block to Japan and then send my GT500 engine block back to OZ.
Crate can be wood or metal box but must conform to Australia and Japanese quarantine standards. Basically world wide shipping crate.
I'm not after a pallet but proper engine crate that the block can be packed up and sealed (nailed shut).
While I'm at it also one for a gearbox as have one sitting at Auto Gallery Yokohama ready to get sent to oz.
Any info, much appreciated
Dont know if this is best spot for this so if not can mods move it
https://www.sau.com.au/forums/topic/336004-engine-shipping-crate-where-to-buy/
Pretty sure t cant be wood unlless you want to have it fumigated. I would get some plastic pallets and fab something up
Theres definitely wooden engine crate (box) which are used for shipping engines world wide.
go straight to your shipping company. they'll have heaps laying around.
Any recommendations of decent reliable shipping company ??
Got carpentry skills?
I have 15x pallets at the front of my place after I'd built a retaining wall. I keep calling Boral to pick them up, and they don't come! :(
Terry, tell them you've got 40 pallets and they will come. Im a builder and we get rid of pallets that are left over after the site is cleaned is if we 'exaggerate' how many pallets we have. Works every time.
What sort of pallets Terry? If they are "Chep" or "Loscam" pallets.. Willl be sprayed on the side of the pallet. They are worth some $$$.. If they are scrap cheap looking pallets, yeah just exaggerate..
Edited by .:: GimpS-R34 ::.
What sort of pallets Terry? If they are "Chep" or "Loscam" pallets.. Willl be sprayed on the side of the pallet. They are worth some $$.. If they are scrap cheap looking pallets, yeah just exaggerate..
Hiya Craig,
About half of them are hardwood because I've dragged them across the road onto a wide council strip & they're damn heavy.
The other half are still well constructed but quite a deal lighter.
They all have BORAL 1300 ****** printed on the side > called them 3x to no avail.
Once I realised how heavy half of them were, I was tempted to drag them up the driveway, chained to the back of the Forester;
...but then I knew I'd be tempted to go a further Km to the highway at 3am and dump them there > let 'Accident Research' officers call Boral lol
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
    • Oh, another question comes to mind though. What sort of shitty fuel are you feeding it. Mine, a turbo, has to be fed 98RON, so it doesn't ping itself to death. 98 in Oz is good, dense fuel with minimal oxygenated compounds. Meaning that the energy density is high, and if the O2 trim is working, you will get more MPG than with a lesser fuel. If you're using some sort of piss poor E10 blend with some other MBTE or other oxygenated additions, that could explain using more per mile.
    • I have no idea where the thump is coming from, it sounds like its from behind me but im not exactly sure. And it was the HICAS light that came on.   I think a complete delete is the route im going to go. Probably going to pick up the kit within the next month and get it installed. HICAS is just going to end up being a headache if I keep it.    Thanks you.
    • Just putting this here for reference for other beginners. Similar to what I said above.  I learnt if you have a few dents that are fairly close to each other (within a couple of inches maybe 2-4 inches?) Use filler across them all and sand it all at once with the long block as opposed to fixing them seperately.  Will make life MUCH easier because you won't get stuck in the cycle that I did. I think doing it seperately there is some overlap (mean your whole repair zone might cover near the area of the other dent) and you start sanding near the other dent making a low spot.
