Hey fellow skyliners,I own a r32 rb20det, with light mods:
Blitz suspower pod
Blitz fmic (the one which plumbs back to stock piping)
Di splitfire coilpacks
3" exhaust from turbo (need highflow cat)
Wahlbro fuel pump
Turbosmart e-boost street.
Looking to add z32afm, and later bigger turbo and injectors.I undrstand that the emanage will be able to be tuned to run Above setup but can it be tuned for cams and slight internal work? Like head work, cams etc....
Thank you
NikGee
P.s. Does anyone know in Sydney who will tune a emanate ultimate??
Edited by NikGee
https://www.sau.com.au/forums/topic/336007-emanage-ultimate-ecu/
Of course, but you will need to find a tuner that is comfortable with tuning with it most importantly. I don't know anyone up in Sydney although Cihan (etuner) gets up there occasionally.
Z32 afm can be swapped for a map sensor if you like for more tuning resolution but it supports most afm's also.
CRD will tune it (and sell you one if you want)
EMU is a good computer but does have it's limitations. I used to run one on my 33 but traded it for a PFC.
The thing I did like about the EMU was it's ease of use and that it has swithchable maps so you could have pulp map and a e85 map.
Great option for mildly modded cars IMO but im no expert
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
